SD formatter no longer works
sw_hunt
Another sketch that's stopped working since updating SDfat and installing the Teensyduino 1.54-beta7 is this SD card formatter sketch. I'm using Teensy 3.6's built-in SD card with a 16GB card. I just want to delete everything on the card or to format it, whichever is easier. Can someone please help fix the sketch or point me to one that will work with the latest libraries and beta Teensyduino? This compiled and worked perfectly a week ago... Many thanks
#define USE_SDIO 1
#include <Adafruit_CharacterOLED.h>//include the OLED library
Adafruit_CharacterOLED lcd(OLED_V2, 2, 3, 4, 5, 6, 7, 8); // 2004 OLED!
const uint8_t chipSelect = SS;
// Initialize at highest supported speed not over 50 MHz.
// Reduce max speed if errors occur.
#define SPI_SPEED SD_SCK_MHZ(50)
// Print extra info for debug if DEBUG_PRINT is nonzero
#define DEBUG_PRINT 0
#include "SdFat.h"
#include "sdios.h"
#if DEBUG_PRINT
#include "FreeStack.h"
#endif  // DEBUG_PRINT
// Serial output stream
ArduinoOutStream cout(Serial);
#if USE_SDIO
// Use faster SdioCardEX
SdioCardEX card;
// SdioCard card;
#else  // USE_SDIO
Sd2Card card;
#endif  // USE_SDIO
uint32_t cardSizeBlocks;
uint32_t cardCapacityMB;
// cache for SD block
cache_t cache;
// MBR information
uint8_t partType;
uint32_t relSector;
uint32_t partSize;
// Fake disk geometry
uint8_t numberOfHeads;
uint8_t sectorsPerTrack;
// FAT parameters
uint16_t reservedSectors;
uint8_t sectorsPerCluster;
uint32_t fatStart;
uint32_t fatSize;
uint32_t dataStart;
// constants for file system structure
uint16_t const BU16 = 128;
uint16_t const BU32 = 8192;
//  strings needed in file system structures
char noName[] = "NO NAME    ";
char fat16str[] = "FAT16   ";
char fat32str[] = "FAT32   ";
#define sdError(msg) {cout << F("error: ") << F(msg) << endl; sdErrorHalt();}
void sdErrorHalt() {
  if (card.errorCode()) {
    cout << F("SD error: ") << hex << int(card.errorCode());
    cout << ',' << int(card.errorData()) << dec << endl;
  SysCall::halt();
#if DEBUG_PRINT
void debugPrint() {
  cout << F("FreeStack: ") << FreeStack() << endl;
  cout << F("partStart: ") << relSector << endl;
  cout << F("partSize: ") << partSize << endl;
  cout << F("reserved: ") << reservedSectors << endl;
  cout << F("fatStart: ") << fatStart << endl;
  cout << F("fatSize: ") << fatSize << endl;
  cout << F("dataStart: ") << dataStart << endl;
  cout << F("clusterCount: ");
  cout << ((relSector + partSize - dataStart)/sectorsPerCluster) << endl;
  cout << endl;
  cout << F("Heads: ") << int(numberOfHeads) << endl;
  cout << F("Sectors: ") << int(sectorsPerTrack) << endl;
  cout << F("Cylinders: ");
  cout << cardSizeBlocks/(numberOfHeads*sectorsPerTrack) << endl;
// write cached block to the card
uint8_t writeCache(uint32_t lbn) {
  return card.writeBlock(lbn, cache.data);
// initialize appropriate sizes for SD capacity
void initSizes() {
  if (cardCapacityMB <= 6) {
    sdError("Card is too small.");
  } else if (cardCapacityMB <= 16) {
    sectorsPerCluster = 2;
  } else if (cardCapacityMB <= 32) {
    sectorsPerCluster = 4;
  } else if (cardCapacityMB <= 64) {
    sectorsPerCluster = 8;
  } else if (cardCapacityMB <= 128) {
    sectorsPerCluster = 16;
  } else if (cardCapacityMB <= 1024) {
    sectorsPerCluster = 32;
  } else if (cardCapacityMB <= 32768) {
    sectorsPerCluster = 64;
    // SDXC cards
    sectorsPerCluster = 128;
  cout << F("Blocks/Cluster: ") << int(sectorsPerCluster) << endl;
  // set fake disk geometry
  sectorsPerTrack = cardCapacityMB <= 256 ? 32 : 63;
    numberOfHeads = 2;
    numberOfHeads = 4;
    numberOfHeads = 8;
  } else if (cardCapacityMB <= 504) {
    numberOfHeads = 16;
  } else if (cardCapacityMB <= 1008) {
    numberOfHeads = 32;
  } else if (cardCapacityMB <= 2016) {
    numberOfHeads = 64;
  } else if (cardCapacityMB <= 4032) {
    numberOfHeads = 128;
    numberOfHeads = 255;
// zero cache and optionally set the sector signature
void clearCache(uint8_t addSig) {
  memset(&cache, 0, sizeof(cache));
  if (addSig) {
    cache.mbr.mbrSig0 = BOOTSIG0;
    cache.mbr.mbrSig1 = BOOTSIG1;
// zero FAT and root dir area on SD
void clearFatDir(uint32_t bgn, uint32_t count) {
  clearCache(false);
#if USE_SDIO
  for (uint32_t i = 0; i < count; i++) {
    if (!card.writeBlock(bgn + i, cache.data)) {
       sdError("Clear FAT/DIR writeBlock failed");
    if ((i & 0XFF) == 0) {
      cout << '.';
#else  // USE_SDIO
  if (!card.writeStart(bgn, count)) {
    sdError("Clear FAT/DIR writeStart failed");
      cout << '.';
    if (!card.writeData(cache.data)) {
      sdError("Clear FAT/DIR writeData failed");
  if (!card.writeStop()) {
    sdError("Clear FAT/DIR writeStop failed");
#endif  // USE_SDIO
  cout << endl;
// return cylinder number for a logical block number
uint16_t lbnToCylinder(uint32_t lbn) {
  return lbn / (numberOfHeads * sectorsPerTrack);
// return head number for a logical block number
uint8_t lbnToHead(uint32_t lbn) {
  return (lbn % (numberOfHeads * sectorsPerTrack)) / sectorsPerTrack;
// return sector number for a logical block number
uint8_t lbnToSector(uint32_t lbn) {
  return (lbn % sectorsPerTrack) + 1;
// format and write the Master Boot Record
void writeMbr() {
  clearCache(true);
  part_t* p = cache.mbr.part;
  p->boot = 0;
  uint16_t c = lbnToCylinder(relSector);
  if (c > 1023) {
    sdError("MBR CHS");
  p->beginCylinderHigh = c >> 8;
  p->beginCylinderLow = c & 0XFF;
  p->beginHead = lbnToHead(relSector);
  p->beginSector = lbnToSector(relSector);
  p->type = partType;
  uint32_t endLbn = relSector + partSize - 1;
  c = lbnToCylinder(endLbn);
  if (c <= 1023) {
    p->endCylinderHigh = c >> 8;
    p->endCylinderLow = c & 0XFF;
    p->endHead = lbnToHead(endLbn);
    p->endSector = lbnToSector(endLbn);
    // Too big flag, c = 1023, h = 254, s = 63
    p->endCylinderHigh = 3;
    p->endCylinderLow = 255;
    p->endHead = 254;
    p->endSector = 63;
  p->firstSector = relSector;
  p->totalSectors = partSize;
  if (!writeCache(0)) {
    sdError("write MBR");
// generate serial number from card size and micros since boot
uint32_t volSerialNumber() {
  return (cardSizeBlocks << 8) + micros();
// format the SD as FAT16
void makeFat16() {
  uint32_t nc;
  for (dataStart = 2 * BU16;; dataStart += BU16) {
    nc = (cardSizeBlocks - dataStart)/sectorsPerCluster;
    fatSize = (nc + 2 + 255)/256;
    uint32_t r = BU16 + 1 + 2 * fatSize + 32;
    if (dataStart < r) {
      continue;
    relSector = dataStart - r + BU16;
  // check valid cluster count for FAT16 volume
  if (nc < 4085 || nc >= 65525) {
    sdError("Bad cluster count");
  reservedSectors = 1;
  fatStart = relSector + reservedSectors;
  partSize = nc * sectorsPerCluster + 2 * fatSize + reservedSectors + 32;
  if (partSize < 32680) {
    partType = 0X01;
  } else if (partSize < 65536) {
    partType = 0X04;
    partType = 0X06;
  // write MBR
  writeMbr();
  clearCache(true);
  fat_boot_t* pb = &cache.fbs;
  pb->jump[0] = 0XEB;
  pb->jump[1] = 0X00;
  pb->jump[2] = 0X90;
  for (uint8_t i = 0; i < sizeof(pb->oemId); i++) {
    pb->oemId[i] = ' ';
  pb->bytesPerSector = 512;
  pb->sectorsPerCluster = sectorsPerCluster;
  pb->reservedSectorCount = reservedSectors;
  pb->fatCount = 2;
  pb->rootDirEntryCount = 512;
  pb->mediaType = 0XF8;
  pb->sectorsPerFat16 = fatSize;
  pb->sectorsPerTrack = sectorsPerTrack;
  pb->headCount = numberOfHeads;
  pb->hidddenSectors = relSector;
  pb->totalSectors32 = partSize;
  pb->driveNumber = 0X80;
  pb->bootSignature = EXTENDED_BOOT_SIG;
  pb->volumeSerialNumber = volSerialNumber();
  memcpy(pb->volumeLabel, noName, sizeof(pb->volumeLabel));
  memcpy(pb->fileSystemType, fat16str, sizeof(pb->fileSystemType));
  // write partition boot sector
  if (!writeCache(relSector)) {
    sdError("FAT16 write PBS failed");
  // clear FAT and root directory
  clearFatDir(fatStart, dataStart - fatStart);
  clearCache(false);
  cache.fat16[0] = 0XFFF8;
  cache.fat16[1] = 0XFFFF;
  // write first block of FAT and backup for reserved clusters
  if (!writeCache(fatStart)
      || !writeCache(fatStart + fatSize)) {
    sdError("FAT16 reserve failed");
// format the SD as FAT32
void makeFat32() {
  uint32_t nc;
  relSector = BU32;
  for (dataStart = 2 * BU32;; dataStart += BU32) {
    fatSize = (nc + 2 + 127)/128;
    uint32_t r = relSector + 9 + 2 * fatSize;
    if (dataStart >= r) {
  // error if too few clusters in FAT32 volume
  if (nc < 65525) {
  reservedSectors = dataStart - relSector - 2 * fatSize;
  partSize = nc * sectorsPerCluster + dataStart - relSector;
  // type depends on address of end sector
  // max CHS has lbn = 16450560 = 1024*255*63
  if ((relSector + partSize) <= 16450560) {
    // FAT32
    partType = 0X0B;
    // FAT32 with INT 13
    partType = 0X0C;
  writeMbr();
  clearCache(true);
  fat32_boot_t* pb = &cache.fbs32;
  pb->jump[0] = 0XEB;
  pb->jump[1] = 0X00;
  pb->jump[2] = 0X90;
    pb->oemId[i] = ' ';
  pb->fatCount = 2;
  pb->sectorsPerFat32 = fatSize;
  pb->fat32RootCluster = 2;
  pb->fat32FSInfo = 1;
  pb->fat32BackBootBlock = 6;
  memcpy(pb->fileSystemType, fat32str, sizeof(pb->fileSystemType));
  // write partition boot sector and backup
      || !writeCache(relSector + 6)) {
    sdError("FAT32 write PBS failed");
  clearCache(true);
  // write extra boot area and backup
  if (!writeCache(relSector + 2)
      || !writeCache(relSector + 8)) {
    sdError("FAT32 PBS ext failed");
  fat32_fsinfo_t* pf = &cache.fsinfo;
  pf->leadSignature = FSINFO_LEAD_SIG;
  pf->structSignature = FSINFO_STRUCT_SIG;
  pf->freeCount = 0XFFFFFFFF;
  pf->nextFree = 0XFFFFFFFF;
  // write FSINFO sector and backup
  if (!writeCache(relSector + 1)
      || !writeCache(relSector + 7)) {
    sdError("FAT32 FSINFO failed");
  clearFatDir(fatStart, 2 * fatSize + sectorsPerCluster);
  clearCache(false);
  cache.fat32[0] = 0x0FFFFFF8;
  cache.fat32[1] = 0x0FFFFFFF;
  cache.fat32[2] = 0x0FFFFFFF;
    sdError("FAT32 reserve failed");
// flash erase all data
uint32_t const ERASE_SIZE = 262144L;
void eraseCard() {
  cout << endl << F("Erasing\n");
  uint32_t firstBlock = 0;
  uint32_t lastBlock;
  uint16_t n = 0;
  do {
    lastBlock = firstBlock + ERASE_SIZE - 1;
    if (lastBlock >= cardSizeBlocks) {
      lastBlock = cardSizeBlocks - 1;
    if (!card.erase(firstBlock, lastBlock)) {
      sdError("erase failed");
    cout << '.';
    if ((n++)%32 == 31) {
      cout << endl;
    firstBlock += ERASE_SIZE;
  } while (firstBlock < cardSizeBlocks);
  cout << endl;
  if (!card.readBlock(0, cache.data)) {
    sdError("readBlock");
  cout << hex << showbase << setfill('0') << internal;
  cout << F("All data set to ") << setw(4) << int(cache.data[0]) << endl;
  cout << dec << noshowbase << setfill(' ') << right;
  cout << F("Erase done\n");
void formatCard() {
  cout << endl;
  cout << F("Formatting\n");
  initSizes();
  if (card.type() != SD_CARD_TYPE_SDHC) {
    cout << F("FAT16\n");
    makeFat16();
    cout << F("FAT32\n");
    makeFat32();
#if DEBUG_PRINT
  debugPrint();
  cout << F("Format done\n");
  lcd.begin(20, 4);// Initialize the OLED with 20 characters and 4 lines
  lcd.display(); // makes sure it's turned on in case last operation had timedout
  blankDisplay();
  lcd.home();
  lcd.print("Formatting SD card  ");
 #if USE_SDIO
  if (!card.begin()) {
    sdError("card.begin failed");
    lcd.setCursor(0, 0); lcd.print ("Failed 1            ");
#else  // USE_SDIO
  if (!card.begin(chipSelect, SPI_SPEED)) {
    cout << F(
           "\nSD initialization failure!\n"
           "Is the SD card inserted correctly?\n"
           "Is chip select correct at the top of this program?\n");
    lcd.setCursor(0, 0); lcd.print ("Failed 2            ");
  cardSizeBlocks = card.cardSize();
  if (cardSizeBlocks == 0) {
    sdError("cardSize");
    lcd.setCursor(0, 0); lcd.print ("Failed 3            ");
  cardCapacityMB = (cardSizeBlocks + 2047)/2048;
//    eraseCard();
    formatCard();
lcd.setCursor(0, 0); lcd.print ("Completed Formatting");
void blankDisplay() {
  lcd.setCursor(0, 0); lcd.print("                    ");
  lcd.setCursor(0, 1); lcd.print("                    ");
  lcd.setCursor(0, 2); lcd.print("                    ");
  lcd.setCursor(0, 3); lcd.print("                    ");
void loop() {}
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Steve\AppData\Local\Arduino15\packages -hardware F:\Documents\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Steve\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries F:\Documents\Arduino\libraries -fqbn=teensy:avr:teensy36:usb=serial,speed=180,opt=o2std,keys=en-gb -ide-version=10813 -build-path C:\Users\Steve\AppData\Local\Temp\arduino_build_624411 -warnings=none -build-cache C:\Users\Steve\AppData\Local\Temp\arduino_cache_923832 -verbose F:\Documents\Arduino\LFE\Utilities\SdFormatter_v2\SdFormatter_v2.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Steve\AppData\Local\Arduino15\packages -hardware F:\Documents\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Steve\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries F:\Documents\Arduino\libraries -fqbn=teensy:avr:teensy36:usb=serial,speed=180,opt=o2std,keys=en-gb -ide-version=10813 -build-path C:\Users\Steve\AppData\Local\Temp\arduino_build_624411 -warnings=none -build-cache C:\Users\Steve\AppData\Local\Temp\arduino_cache_923832 -verbose F:\Documents\Arduino\LFE\Utilities\SdFormatter_v2\SdFormatter_v2.ino
Using board 'teensy36' from platform in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr
Using core 'teensy3' from platform in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr
Detecting libraries used...
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=154 -DARDUINO=10813 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_UNITED_KINGDOM "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\Steve\\AppData\\Local\\Temp\\arduino_build_624411\\sketch\\SdFormatter_v2.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for Adafruit_CharacterOLED.h: [Adafruit_CharacterOLED-master]
ResolveLibrary(Adafruit_CharacterOLED.h)
  -> candidates: [Adafruit_CharacterOLED-master]
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=154 -DARDUINO=10813 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_UNITED_KINGDOM "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IF:\\Documents\\Arduino\\libraries\\Adafruit_CharacterOLED-master" "C:\\Users\\Steve\\AppData\\Local\\Temp\\arduino_build_624411\\sketch\\SdFormatter_v2.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for SPI.h: [SPI@1.0]
ResolveLibrary(SPI.h)
  -> candidates: [SPI@1.0]
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=154 -DARDUINO=10813 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_UNITED_KINGDOM "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IF:\\Documents\\Arduino\\libraries\\Adafruit_CharacterOLED-master" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "C:\\Users\\Steve\\AppData\\Local\\Temp\\arduino_build_624411\\sketch\\SdFormatter_v2.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for SdFat.h: [arduino_91745@2.0.2 arduino_887566@2.0.5 SdFat-master@2.0.6 SdFat@2.0.5-beta.1]
ResolveLibrary(SdFat.h)
  -> candidates: [arduino_91745@2.0.2 arduino_887566@2.0.5 SdFat-master@2.0.6 SdFat@2.0.5-beta.1]
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=154 -DARDUINO=10813 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_UNITED_KINGDOM "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IF:\\Documents\\Arduino\\libraries\\Adafruit_CharacterOLED-master" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src" "C:\\Users\\Steve\\AppData\\Local\\Temp\\arduino_build_624411\\sketch\\SdFormatter_v2.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=154 -DARDUINO=10813 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_UNITED_KINGDOM "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IF:\\Documents\\Arduino\\libraries\\Adafruit_CharacterOLED-master" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src" "F:\\Documents\\Arduino\\libraries\\Adafruit_CharacterOLED-master\\Adafruit_CharacterOLED.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=154 -DARDUINO=10813 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_UNITED_KINGDOM "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IF:\\Documents\\Arduino\\libraries\\Adafruit_CharacterOLED-master" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI\\SPI.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=154 -DARDUINO=10813 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_UNITED_KINGDOM "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IF:\\Documents\\Arduino\\libraries\\Adafruit_CharacterOLED-master" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src\\ExFatLib\\ExFatDbg.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=154 -DARDUINO=10813 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_UNITED_KINGDOM "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IF:\\Documents\\Arduino\\libraries\\Adafruit_CharacterOLED-master" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src\\ExFatLib\\ExFatFile.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=154 -DARDUINO=10813 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_UNITED_KINGDOM "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IF:\\Documents\\Arduino\\libraries\\Adafruit_CharacterOLED-master" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src\\ExFatLib\\ExFatFilePrint.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=154 -DARDUINO=10813 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_UNITED_KINGDOM "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IF:\\Documents\\Arduino\\libraries\\Adafruit_CharacterOLED-master" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src\\ExFatLib\\ExFatFileWrite.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=154 -DARDUINO=10813 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_UNITED_KINGDOM "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IF:\\Documents\\Arduino\\libraries\\Adafruit_CharacterOLED-master" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src\\ExFatLib\\ExFatFormatter.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=154 -DARDUINO=10813 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_UNITED_KINGDOM "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IF:\\Documents\\Arduino\\libraries\\Adafruit_CharacterOLED-master" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src\\ExFatLib\\ExFatPartition.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=154 -DARDUINO=10813 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_UNITED_KINGDOM "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IF:\\Documents\\Arduino\\libraries\\Adafruit_CharacterOLED-master" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src\\ExFatLib\\ExFatVolume.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=154 -DARDUINO=10813 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_UNITED_KINGDOM "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IF:\\Documents\\Arduino\\libraries\\Adafruit_CharacterOLED-master" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src\\ExFatLib\\upcase.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=154 -DARDUINO=10813 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_UNITED_KINGDOM "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IF:\\Documents\\Arduino\\libraries\\Adafruit_CharacterOLED-master" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src\\FatLib\\FatDbg.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=154 -DARDUINO=10813 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_UNITED_KINGDOM "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IF:\\Documents\\Arduino\\libraries\\Adafruit_CharacterOLED-master" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src\\FatLib\\FatFile.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=154 -DARDUINO=10813 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_UNITED_KINGDOM "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IF:\\Documents\\Arduino\\libraries\\Adafruit_CharacterOLED-master" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src\\FatLib\\FatFileLFN.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=154 -DARDUINO=10813 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_UNITED_KINGDOM "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IF:\\Documents\\Arduino\\libraries\\Adafruit_CharacterOLED-master" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src\\FatLib\\FatFilePrint.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=154 -DARDUINO=10813 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_UNITED_KINGDOM "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IF:\\Documents\\Arduino\\libraries\\Adafruit_CharacterOLED-master" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src\\FatLib\\FatFileSFN.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=154 -DARDUINO=10813 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_UNITED_KINGDOM "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IF:\\Documents\\Arduino\\libraries\\Adafruit_CharacterOLED-master" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src\\FatLib\\FatFormatter.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=154 -DARDUINO=10813 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_UNITED_KINGDOM "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IF:\\Documents\\Arduino\\libraries\\Adafruit_CharacterOLED-master" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src\\FatLib\\FatPartition.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=154 -DARDUINO=10813 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_UNITED_KINGDOM "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IF:\\Documents\\Arduino\\libraries\\Adafruit_CharacterOLED-master" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src\\FatLib\\FatVolume.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=154 -DARDUINO=10813 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_UNITED_KINGDOM "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IF:\\Documents\\Arduino\\libraries\\Adafruit_CharacterOLED-master" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src\\FreeStack.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=154 -DARDUINO=10813 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_UNITED_KINGDOM "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IF:\\Documents\\Arduino\\libraries\\Adafruit_CharacterOLED-master" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src\\FsLib\\FsFile.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=154 -DARDUINO=10813 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_UNITED_KINGDOM "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IF:\\Documents\\Arduino\\libraries\\Adafruit_CharacterOLED-master" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src\\FsLib\\FsNew.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=154 -DARDUINO=10813 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_UNITED_KINGDOM "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IF:\\Documents\\Arduino\\libraries\\Adafruit_CharacterOLED-master" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src\\FsLib\\FsVolume.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=154 -DARDUINO=10813 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_UNITED_KINGDOM "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IF:\\Documents\\Arduino\\libraries\\Adafruit_CharacterOLED-master" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src\\MinimumSerial.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=154 -DARDUINO=10813 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_UNITED_KINGDOM "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IF:\\Documents\\Arduino\\libraries\\Adafruit_CharacterOLED-master" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src\\SdCard\\SdCardInfo.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=154 -DARDUINO=10813 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_UNITED_KINGDOM "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IF:\\Documents\\Arduino\\libraries\\Adafruit_CharacterOLED-master" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src\\SdCard\\SdSpiCard.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=154 -DARDUINO=10813 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_UNITED_KINGDOM "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IF:\\Documents\\Arduino\\libraries\\Adafruit_CharacterOLED-master" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src\\SdCard\\SdioTeensy.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=154 -DARDUINO=10813 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_UNITED_KINGDOM "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IF:\\Documents\\Arduino\\libraries\\Adafruit_CharacterOLED-master" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src\\SpiDriver\\SdSpiArtemis.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=154 -DARDUINO=10813 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_UNITED_KINGDOM "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IF:\\Documents\\Arduino\\libraries\\Adafruit_CharacterOLED-master" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src\\SpiDriver\\SdSpiChipSelect.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=154 -DARDUINO=10813 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_UNITED_KINGDOM "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IF:\\Documents\\Arduino\\libraries\\Adafruit_CharacterOLED-master" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src\\SpiDriver\\SdSpiDue.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=154 -DARDUINO=10813 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_UNITED_KINGDOM "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IF:\\Documents\\Arduino\\libraries\\Adafruit_CharacterOLED-master" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src\\SpiDriver\\SdSpiESP.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=154 -DARDUINO=10813 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_UNITED_KINGDOM "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IF:\\Documents\\Arduino\\libraries\\Adafruit_CharacterOLED-master" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src\\SpiDriver\\SdSpiParticle.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=154 -DARDUINO=10813 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_UNITED_KINGDOM "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IF:\\Documents\\Arduino\\libraries\\Adafruit_CharacterOLED-master" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src\\SpiDriver\\SdSpiSTM32.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=154 -DARDUINO=10813 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_UNITED_KINGDOM "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IF:\\Documents\\Arduino\\libraries\\Adafruit_CharacterOLED-master" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src\\SpiDriver\\SdSpiTeensy3.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=154 -DARDUINO=10813 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_UNITED_KINGDOM "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IF:\\Documents\\Arduino\\libraries\\Adafruit_CharacterOLED-master" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src\\common\\FmtNumber.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=154 -DARDUINO=10813 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_UNITED_KINGDOM "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IF:\\Documents\\Arduino\\libraries\\Adafruit_CharacterOLED-master" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src\\common\\FsCache.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=154 -DARDUINO=10813 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_UNITED_KINGDOM "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IF:\\Documents\\Arduino\\libraries\\Adafruit_CharacterOLED-master" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src\\common\\FsDateTime.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=154 -DARDUINO=10813 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_UNITED_KINGDOM "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IF:\\Documents\\Arduino\\libraries\\Adafruit_CharacterOLED-master" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src\\common\\FsStructs.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=154 -DARDUINO=10813 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_UNITED_KINGDOM "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IF:\\Documents\\Arduino\\libraries\\Adafruit_CharacterOLED-master" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src\\common\\PrintBasic.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=154 -DARDUINO=10813 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_UNITED_KINGDOM "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IF:\\Documents\\Arduino\\libraries\\Adafruit_CharacterOLED-master" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src\\common\\SysCallBareUno.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=154 -DARDUINO=10813 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_UNITED_KINGDOM "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IF:\\Documents\\Arduino\\libraries\\Adafruit_CharacterOLED-master" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src\\iostream\\StdioStream.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=154 -DARDUINO=10813 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_UNITED_KINGDOM "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IF:\\Documents\\Arduino\\libraries\\Adafruit_CharacterOLED-master" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src\\iostream\\StreamBaseClass.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=154 -DARDUINO=10813 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_UNITED_KINGDOM "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IF:\\Documents\\Arduino\\libraries\\Adafruit_CharacterOLED-master" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src\\iostream\\istream.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=154 -DARDUINO=10813 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_UNITED_KINGDOM "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IF:\\Documents\\Arduino\\libraries\\Adafruit_CharacterOLED-master" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src\\iostream\\ostream.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Generating function prototypes...
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=154 -DARDUINO=10813 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_UNITED_KINGDOM "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IF:\\Documents\\Arduino\\libraries\\Adafruit_CharacterOLED-master" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src" "C:\\Users\\Steve\\AppData\\Local\\Temp\\arduino_build_624411\\sketch\\SdFormatter_v2.ino.cpp" -o "C:\\Users\\Steve\\AppData\\Local\\Temp\\arduino_build_624411\\preproc\\ctags_target_for_gcc_minus_e.cpp" -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\Steve\\AppData\\Local\\Temp\\arduino_build_624411\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/precompile_helper" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr/cores/teensy3" "C:\\Users\\Steve\\AppData\\Local\\Temp\\arduino_build_624411" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -x c++-header -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=154 -DARDUINO=10813 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_UNITED_KINGDOM "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr/cores/teensy3" "C:\\Users\\Steve\\AppData\\Local\\Temp\\arduino_build_624411/pch/Arduino.h" -o "C:\\Users\\Steve\\AppData\\Local\\Temp\\arduino_build_624411/pch/Arduino.h.gch"
Using previously compiled file: C:\Users\Steve\AppData\Local\Temp\arduino_build_624411\pch\Arduino.h.gch
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=154 -DARDUINO=10813 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_UNITED_KINGDOM "-IC:\\Users\\Steve\\AppData\\Local\\Temp\\arduino_build_624411/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IF:\\Documents\\Arduino\\libraries\\Adafruit_CharacterOLED-master" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src" "C:\\Users\\Steve\\AppData\\Local\\Temp\\arduino_build_624411\\sketch\\SdFormatter_v2.ino.cpp" -o "C:\\Users\\Steve\\AppData\\Local\\Temp\\arduino_build_624411\\sketch\\SdFormatter_v2.ino.cpp.o"
SdFormatter_v2:25: error: 'SdioCardEX' does not name a type
 SdioCardEX card;
SdFormatter_v2: In function 'void sdErrorHalt()':
SdFormatter_v2:65: error: 'card' was not declared in this scope
SdFormatter_v2: In function 'uint8_t writeCache(uint32_t)':
SdFormatter_v2:93: error: 'card' was not declared in this scope
SdFormatter_v2: In function 'void clearCache(uint8_t)':
SdFormatter_v2:144: error: 'union cache_t' has no member named 'mbr'
SdFormatter_v2:144: error: 'BOOTSIG0' was not declared in this scope
SdFormatter_v2:145: error: 'union cache_t' has no member named 'mbr'
SdFormatter_v2:145: error: 'BOOTSIG1' was not declared in this scope
SdFormatter_v2: In function 'void clearFatDir(uint32_t, uint32_t)':
SdFormatter_v2:154: error: 'card' was not declared in this scope
SdFormatter_v2: In function 'void writeMbr()':
SdFormatter_v2:198: error: 'part_t' was not declared in this scope
SdFormatter_v2:198: error: 'p' was not declared in this scope
SdFormatter_v2:198: error: 'union cache_t' has no member named 'mbr'
SdFormatter_v2: In function 'void makeFat16()':
SdFormatter_v2:265: error: 'fat_boot_t' was not declared in this scope
SdFormatter_v2:265: error: 'pb' was not declared in this scope
SdFormatter_v2:265: error: 'union cache_t' has no member named 'fbs'
SdFormatter_v2:284: error: 'EXTENDED_BOOT_SIG' was not declared in this scope
SdFormatter_v2: In function 'void makeFat32()':
SdFormatter_v2:335: error: 'fat32_boot_t' was not declared in this scope
SdFormatter_v2:335: error: 'pb' was not declared in this scope
SdFormatter_v2:335: error: 'union cache_t' has no member named 'fbs32'
SdFormatter_v2:356: error: 'EXTENDED_BOOT_SIG' was not declared in this scope
SdFormatter_v2:371: error: 'fat32_fsinfo_t' was not declared in this scope
SdFormatter_v2:371: error: 'pf' was not declared in this scope
SdFormatter_v2:371: error: 'union cache_t' has no member named 'fsinfo'
SdFormatter_v2:372: error: 'FSINFO_LEAD_SIG' was not declared in this scope
SdFormatter_v2:373: error: 'FSINFO_STRUCT_SIG' was not declared in this scope
SdFormatter_v2: In function 'void eraseCard()':
SdFormatter_v2:406: error: 'card' was not declared in this scope
SdFormatter_v2:417: error: 'card' was not declared in this scope
SdFormatter_v2: In function 'void formatCard()':
SdFormatter_v2:430: error: 'card' was not declared in this scope
SdFormatter_v2: In function 'void setup()':
SdFormatter_v2:454: error: 'card' was not declared in this scope
SdFormatter_v2:468: error: 'card' was not declared in this scope
Multiple libraries were found for "SdFat.h"
 Used: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SdFat
 Not used: F:\Documents\Arduino\libraries\arduino_91745
 Not used: F:\Documents\Arduino\libraries\arduino_887566
 Not used: F:\Documents\Arduino\libraries\SdFat-master
Using library Adafruit_CharacterOLED-master in folder: F:\Documents\Arduino\libraries\Adafruit_CharacterOLED-master (legacy)
Using library SPI at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI
Using library SdFat at version 2.0.5-beta.1 in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SdFat
It seems that the example was using a very transient implementation of SdFat as indicated by
SdioCardEX card;
maybe you try first the SDFormatter examples provided with SdFat library.
or ask the person that implemented your example to port it to SdFat-V2 (the one used in TD)
Thanks, just tried the example again and it's great. First time I hadn't got the serial monitor engaged and missed the 'are you sure in triplicate?' messages and thought it wasn't working...
