Results 1 to 11 of 11
Thread: No sound at the headphone output with audio board.
    Apr 2021
    8
    I have searched and tried a lot but I have a problem with the audio board and Teensy 4.1.
    There is no sound at the headphone output.
    Which pins must at least be connected for this? And do you have to make changes to the library for the version with Teensy 4.1?
    Many thanks for your help.
    1,606
    Are you using the Rev D audio board?
    Post a photo which clearly shows the audio board and T4.1 connected together.
    The audio library works with T4.1
    Pete
    Apr 2021
    8
    Yes, I have the Rev D.
    I tested it with the examples from the library. And Frank Boesing's mp3 player.
    I can only take pictures on Friday because I'm on the road for work.
    8,281
    Some general rules:
    Don't use a low quality breadboard, no low quality china cables. If cables, they should be a short as possible (really).
    Minimum - for audio - pins are 7, 8, 18, 19, 20, 21, 23, GND, 3V3 - and look here: https://www.pjrc.com/store/teensy3_audio.html
    Apr 2021
    8
    Thanks for the tips. I soldered the audio board with 2 cm short wires directly over the Teensy.
    I connected pins 7, 8, 18, 19, 20, 21, 23, GND, 3V3. According to the description of PJRC. But unfortunately there is no sound.
    24,088
    Did you solder GND which is next to pin 0, or GND which is between VIN and 3.3V?
    The one next to pin 0 (on the audio shield) must be connected. It will not work if you used a wire only on the other GND.
    Apr 2021
    8
    I solder both GND Pins ;-)
    Apr 2021
    8
    Tomorrow I'll get another audio board and another Teensy. Maybe I damaged something while soldering.
    Apr 2021
    8
    I found the mistake. The connection had a pin offset at 7 and 8. Now it works.
    Thank you very much. Especially to Paul and Frank.
    That was a "stupid mistake". I looked for the fault for three days. Shame on me...
    8,281
    happens
    Been there..
    Glad that it works now
    24,088
    Oh, I know that mistake well too!
