Results 1 to 5 of 5
Thread: Audio codec 44.1K to 48K migration.
    Apr 2021
    3
    Can somebody advise me how to modify the Audio library to work with 12.288MHz crystal for the WM8731 codec?
    24,076
    Which Teensy are you using? The process is different on Teensy 4.x than the older boards.
    Apr 2021
    3
    It`s 4.1 board.
    24,076
    I believe all you need to do with Teensy 4.0 & 4.1 is edit the sample rate number in AudioStream.h.
    That file is located inside your Arduino folder. When you search for that file, you should find 2 copies. Pay attention to the folder name, as you want to edit the copy used by Teensy 4 rather than the other file for Teensy 3.
    Apr 2021
    3
    Thank you, we`ll check.
