DataLogger, how change the name of a folder name
Hi ,
I use the ready code from IDE library SdFat--examplesV1-->dataLogger-->
 * Simple data logger.
#include "SdFat.h"
// SD chip select pin.  Be sure to disable any other SPI devices such as Enet.
const uint8_t chipSelect = 7;
// Interval between data records in milliseconds.
// The interval must be greater than the maximum SD write latency plus the
// time to acquire and write data to the SD to avoid overrun errors.
// Run the bench example to check the quality of your SD card.
const uint32_t SAMPLE_INTERVAL_MS = 1000;
// Log file base name.  Must be six characters or less.
#define FILE_BASE_NAME "Data"
// File system object.
SdFat sd;
// Log file.
SdFile file;
// Time in micros for next data record.
uint32_t logTime;
// User functions.  Edit writeHeader() and logData() for your requirements.
const uint8_t ANALOG_COUNT = 4;
// Write data header.
void writeHeader() {
  file.print(F("micros"));
  for (uint8_t i = 0; i < ANALOG_COUNT; i++) {
    file.print(F(",adc"));
    file.print(i, DEC);
  file.println();
// Log a data record.
void logData() {
  uint16_t data[ANALOG_COUNT];
  // Read all channels to avoid SD write latency between readings.
    data[i] = analogRead(i);
  // Write data to file.  Start with log time in micros.
  file.print(logTime);
  // Write ADC data to CSV record.
    file.write(',');
    file.print(data[i]);
  file.println();
// Error messages stored in flash.
#define error(msg) sd.errorHalt(F(msg))
  const uint8_t BASE_NAME_SIZE = sizeof(FILE_BASE_NAME) - 1;
  char fileName[13] = FILE_BASE_NAME "00.csv";
  // Wait for USB Serial
  while (!Serial) {
    SysCall::yield();
  Serial.println(F("Type any character to start"));
  while (!Serial.available()) {
    SysCall::yield();
  // Initialize at the highest speed supported by the board that is
  // not over 50 MHz. Try a lower speed if SPI errors occur.
  if (!sd.begin(chipSelect, SD_SCK_MHZ(16))) {
    sd.initErrorHalt();
  // Find an unused file name.
  if (BASE_NAME_SIZE > 6) {
    error("FILE_BASE_NAME too long");
  while (sd.exists(fileName)) {
    if (fileName[BASE_NAME_SIZE + 1] != '9') {
      fileName[BASE_NAME_SIZE + 1]++;
    } else if (fileName[BASE_NAME_SIZE] != '9') {
      fileName[BASE_NAME_SIZE + 1] = '0';
      fileName[BASE_NAME_SIZE]++;
      error("Can't create file name");
  if (!file.open(fileName, O_WRONLY | O_CREAT | O_EXCL)) {
    error("file.open");
  // Read any Serial data.
  do {
    delay(10);
  } while (Serial.available() && Serial.read() >= 0);
  Serial.print(F("Logging to: "));
  Serial.println(fileName);
  Serial.println(F("Type any character to stop"));
  writeHeader();
  // Start on a multiple of the sample interval.
  logTime = micros()/(1000UL*SAMPLE_INTERVAL_MS) + 1;
  logTime *= 1000UL*SAMPLE_INTERVAL_MS;
  // Time for next record.
  logTime += 1000UL*SAMPLE_INTERVAL_MS;
  // Wait for log time.
  int32_t diff;
  do {
    diff = micros() - logTime;
  } while (diff < 0);
  // Check for data rate too high.
  if (diff > 10) {
    error("Missed data record");
  logData();
  // Force data to SD and update the directory entry to avoid data loss.
  if (!file.sync() || file.getWriteError()) {
    error("write error");
  if (Serial.available()) {
    // Close file and stop.
    file.close();
    Serial.println(F("Done"));
    SysCall::halt();
This ready code gives the name of file Data00...Data01..Data02.. and when he done Data99 then it makes an error!
a)How can I change it to go up to Data999 or Data9999...
thank you!
You would need to edit the section that looks like:
Which is incrementing each of the two digits to do the math for 3 or 4 digits.
Or you could change all of it to be quick and dirty, with increased code size...
And maybe do something like:
  char filename[13] = "Data00.csv";
  uint16_t filaname_index = 1;
  #define MAX_FILE_INDEX 10000
  while ((filename_index < MAX_FILE_INDEX ) && sd.exists(fileName))
    snprintf(filename, sizeof(filename), "Data%04u.csv", file_name_index++);
  if (filename_index == MAX_FILE_INDEX)
But warning typed on fly probably has issues and brings in libraries with printf...
thank you for your time KurtE!!
i will try without changing the code, to make it different, I only differentiated some values ​​of the same code and I see that it start from data0000 ....data0001 and goes up to data0099 and then goes to data1000 .... data1001 .... 1002 I do not know why it puts number 1 to first digit.
Βut I noticed that it does not make sense to reach more than data0250 because the fat16/32 format does not allow it to increase the number of files. maybe if it is possible to put them in a folder per 200 files but it goes a long way and there is no reason to do something that ..!!
below are the changes I made:
before:
after:
  char fileName[13] = FILE_BASE_NAME "0000.csv";
Before:
after:
  if (BASE_NAME_SIZE > 10) {
Before:
after:
    if (fileName[BASE_NAME_SIZE + 3] != '9') {
      fileName[BASE_NAME_SIZE + 3]++;
      fileName[BASE_NAME_SIZE + 3] = '0';
