Results 1 to 4 of 4
Thread: Multiple devices on SPI buss RA8875 Tri-Sate issue
    Apr 2020
    Guelph Ontario Canada
    116
    I know there is an issue with Tri-stating on the SPI buss with RA8875 displays ..
    the question I have is if you have 2 devices on the SPI buss that have their own CS lines ...
    Is the tri-state problem still there ?
    or is the SPI Buss corrupted due to conflict with the state of the RA8875 when the other SPI device is selected?
    Thanks .. need some schooling here
    Keith
    4,027
    Paul's paper on better SPI design (https://www.pjrc.com/better-spi-bus-design-in-3-steps/) would indicate that SPI devices having their own CS lines does not prevent the need for tri-stating. The first step might be to add pull-up resistors to the CS and reset lines. But if you are still having problems, you may need to add a tri-state buffer for each display.
    Dec 2016
    Montreal, Canada
    3,692
    Tri-state is not a CS issue unless you have both CS' asserted. The issue is at MISO, some chips don't tri-state that line and it fights with the other slave that is ran in parallel. tri-state buffers exist for these problems
    Apr 2020
    116
    Thankyou for the reply .. I'm struggling with the Ra8876 display which is 7.84" 1280 X 400 pixels and requires SPI for 2 chips on the board SSD2828 is the bridge chip from SDI to MIPI and needs to be set to allow the the passthrough for the ra8876 ... I've tried the forked version ra8876teensylite library which bit banged the other connection but its not working ...So trying to see what can be done..Thanks for the info
