ResistorScorcher
New member
Does anyone have a good estimate as to the latency between a voltage change on a digital pin and when it can be read correctly with DigitalReadFast?
I know that the actual command can be executed in one clock cycle but am not sure if I am going to have to introduce an additional wait period after another chip changes the voltage.
The current plan is to use a teensy 4.1 at 800 MHz to drive the clock of, and record the output of a 1-to-10 ADC chip with the following logic
while(true){
digitalWriteFast(clock, HIGH)
// store past results in memory
digitalWriteFast(clock, LOW)
while(c++<waitTime){
nop;
b1=digitalReadFast(pin1)
