Is there a way to print out the raw digital audio data from the SPH0645 microphone onto the serial console ?; like the data samples in its binary format. I found the code to do this in the Adafruit webpage documenting the microphone. But, its using an I2S library, that will work only with boards with SAMD cores. The code that I found is listed below :
This example reads audio data from an I2S microphone
breakout board, and prints out the samples to the Serial console. The
Serial Plotter built into the Arduino IDE can be used to plot the audio
data (Tools -> Serial Plotter)
Circuit:
* Arduino/Genuino Zero, MKRZero or MKR1000 board
* GND connected GND
* 3.3V connected 3.3V (Zero) or VCC (MKR1000, MKRZero)
* WS connected to pin 0 (Zero) or pin 3 (MKR1000, MKRZero)
* CLK connected to pin 1 (Zero) or pin 2 (MKR1000, MKRZero)
* SD connected to pin 9 (Zero) or pin A6 (MKR1000, MKRZero)
created 17 November 2016
by Sandeep Mistry
#include <I2S.h>
// A baud rate of 115200 is used instead of 9600 for a faster data rate
// on non-native USB ports
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
// start I2S at 16 kHz with 32-bits per sample
if (!I2S.begin(I2S_PHILIPS_MODE, 16000, 32)) {
Serial.println("Failed to initialize I2S!");
while (1); // do nothing
// read a sample
int sample = I2S.read();
if ((sample == 0) || (sample == -1) ) {
return;
// convert to 18 bit signed
sample >>= 14;
// if it's non-zero print value to serial
Serial.println(sample);
I am wondering whether there is an equivalent library that will work with teensy, to do the same. I have a teensy 4.0.
Thanks in advance!!
