Results 1 to 2 of 2
Thread: Fast slew rate setting on Teensy 4.1
    Apr 2021
    2
    StanfordEE was able to get a beautiful 150 MHz square wave from a Teensy 4.0. All I need is 25 MHz square wave from the Teensy 4.1 but everything I try looks like trash... Here is my code:
    #define NOP __asm__ __volatile__ ("nop\n\t")
    #define PIN_A  34 //Pin 34 on Teensy 4.1. GPIO 7.29.
    #define PIN_B  35 //Pin 35 on Teensy 4.1. GPIO 7.28.
    #define PIN_C  36 //Pin 36 on Teensy 4.1. GPIO 7.18.
    //Takes binary # between 000 & 111 (0–7), where LSB -> PIN_A, ..., MSB -> PIN_C,
    //and sets the respective bits in the register so those pins output HIGH:
    void set3BitsInPort7(uint32_t threeBitsToSet) {
      GPIO7_DR_SET = ((threeBitsToSet>> 0) & 1) << CORE_PIN34_BIT  | //PIN_A
                     ((threeBitsToSet>> 1) & 1) << CORE_PIN35_BIT  | //PIN_B
                     ((threeBitsToSet>> 2) & 1) << CORE_PIN36_BIT; //PIN_C
    //Takes binary # between 000 & 111 (0–7), where LSB -> PIN_A, ..., MSB -> PIN_D,
    //and clears the respective bits in the register so those pins output LOW:
    void clear3BitsInPort7(uint32_t threeBitsToClear) {
      GPIO7_DR_CLEAR = ((threeBitsToClear>> 0) & 1) << CORE_PIN34_BIT  | //PIN_A
                       ((threeBitsToClear>> 1) & 1) << CORE_PIN35_BIT  | //PIN_B
                       ((threeBitsToClear>> 2) & 1) << CORE_PIN36_BIT; //PIN_C
      pinMode(PIN_A, OUTPUT);
      pinMode(PIN_B, OUTPUT);
      pinMode(PIN_C, OUTPUT);
      noInterrupts();
      clear3BitsInPort7(7); //Make PIN_A, PIN_B, & PIN_C LOW.
    void yield() {
      while(1) {
        set3BitsInPort7(7); //Make PIN_A, PIN_B, & PIN_C HIGH.
        //delay((n+1)*1/600e6) = delay(20e-9) -> n = 11:
        NOP;
        NOP;
        NOP;
        NOP;
        NOP;
        NOP;
        NOP;
        NOP;
        NOP;
        NOP;
        NOP;
        NOP;
        NOP;
        NOP;
        NOP;
        NOP;
        NOP;
        NOP;
        NOP;
        NOP;
        NOP;
        NOP;
    But this is the waveform I measure on pin 34:
    The frequency is roughly double the target frequency with 10 ns rise and fall times.
    If I use delayNanoseconds(20) instead of the sets of NOPs then the problem is the opposite:
    I.e., the frequency is now half of the target frequency but the 10 ns rise and fall times remain.
    I don't know why NOPs & delayNanoseconds are 2x off from what they should be but I'd like to solve the slew rate issue first: In this post, Paul enables fast slew rate mode on the Teensy 3.5:
      pinMode(13, OUTPUT);
      PORTC_PCR5 &= ~0x04; // disable slew rate limit
      noInterrupts();
      while (1) {
        digitalWriteFast(13, HIGH);
        digitalWriteFast(13, LOW);
    The Teensy 4.1 product page also mentions slew rate limiting:
    This optional feature greatly reduces high frequency noise when long wires are connected to digital output pins. The rate of voltage change on the pin is slowed. The extra time is only nanoseconds, which is enough to lower undesirable high frequency effects which can cause trouble with long wires.
    How do I do this on the Teensy 4.1?
    Apr 2021
    2
    *cricket noises*
    Here is an update as I continue to try and solve this problem; I found the IOMUXC_SW_PAD_CTL_PAD_GPIO_B[n]_[o] registers in the NXP DS and I read their default values which are decimal 4272. The LSB is said to control slew rate speed—with 1->fast and 0->slow—so I set the 3 respective bits high in the following code update:
    #define PIN_A  34 //Pin 34 on Teensy 4.1. GPIO 7.29. MIMXRT1062DVJ6A Pad B1_13.
    #define PIN_B  35 //Pin 35 on Teensy 4.1. GPIO 7.28. MIMXRT1062DVJ6A Pad B1_12.
    #define PIN_C  36 //Pin 36 on Teensy 4.1. GPIO 7.18. MIMXRT1062DVJ6A Pad B1_02.
      noInterrupts();
      IOMUXC_SW_PAD_CTL_PAD_GPIO_B1_02 |= 1;
      IOMUXC_SW_PAD_CTL_PAD_GPIO_B1_12 |= 1;
      IOMUXC_SW_PAD_CTL_PAD_GPIO_B1_13 |= 1;
    void yield() {
      while(1) {
        delayNanoseconds(20);
    But it had 0 effect (i.e., the 10 ns rise/fall times and delayNanoseconds doubling still persists). Can anybody help me with this? I feel like it is very important for any high speed I/O Teensy 4.1 applications.
