Electric Potato
Hey guys,
I'm using the Audio library on a T3.5 and have a W25Q128 flash chip connected (no audio shield but using those same pins)
When I use AudioPlaySerialflashRaw my files are playing back at half speed...I copied the files from my micro SD, and if I use AudioPlaySDWav to play the files direct from the card they are normal. I've used AudioPlaySerialflashRaw in a couple different projects and never run into this, but those used T3.2...I'd assume it's sampling rate related?
