Stathis_ARIS3
Hi ,
I have the teensy 3.2 and when give power from 4X1.2 NiMh Battery ->4.8Volt to Vin and GND the teensy working well,when connect and disconnect the battery, the teensy starts running!
Now the problem!
When i try to use wall AC230volt to DC 12V 1000mA or batterys 2X3.6volt li-ion and after use step down to get 5 volt output and give the 5Volt to Vin and GND on teensy, not working when cut or give power from wall transformer or battery , but if cut and disconnect the cable after from step down the teensy starts running OK!
how do i get teensy to start running when connecting and disconnecting the cable before the step down?
this also happens to me in the simple code of led blinking!
Thank you!!
Now the problem!
Thank you!!
