Hello guys,
i am currently trying some stuff, i am using the st7735 with a teensy3.2 and encoder from Sparkfun. i am using the buttonEvent to scroll down and up(double click in the menu).
there are two questions i have.
i would like to see the value of the encoder first on the screen by turning the encoder, and then if i press the push button the value should be saved on the screen. momentarily i have it reversed, because i have multiple states and require therefore specific limits for (hours, minutes, seconds, R,G,B, ON and OFF times and Intensity). the current (rotating encoder) doesnt show the update of the values on the screen, only if I push the pushbutton and it goes to step 2 of the menu.
i have this done over 2 functions. Menucount and MenuCountdown both function run parallel and react to the menu states.
is there a better way, so that the values on the screen become visable?
second question: i would like to erase the values on the screen if i reach the end of the menu and start all over again, is there a way?
i tried this also on a Oled display and this works much better, and i would like to understand it why.
#define ENCODER_OPTIMIZE_INTERRUPTS
MENU
Set RGB Color combination. double click for moving backwards.
wavelength ws2812 max is at
RED=630nm at 78mw/m2
Green=520 at 37mw/m2
Blue=455nm at 180mW/m2
MENU1 set RED value till 255
MENU2 Set Green value till 255
MENU3 set Blue value till 255
MENU4 set Intensity in PWM
MENU5 set Start
MENU6 set Stop
MENU 7 Seconds
MENU 8 Minutes
MENU 9 Hours
MENU 10 Start
changes that are made since 2020, other buttonevent library is installed,allowing forward and backward movement of the menu (double Click)
Clean up of the whole code.
#include <Encoder.h>
#include <stdio.h>
#include <Arduino.h>
#include <Adafruit_GFX.h> // Core graphics library
#include <Adafruit_ST7735.h> // Hardware-specific library for ST7735
#include <Adafruit_ST7789.h>
#include <FlickerFreePrint.h>
#include <ADC.h>
#include <ButtonEvents.h>
#include <CountUpDownTimer.h> //:)
#include <Adafruit_NeoPixel.h>
// Hardware-specific library for ST7789
// library to draw w/o flicker
// custom fonts for the ILI9341_t3.h
// some defines for pins
#define TFT_MISO 12
#define TFT_MOSI 11 //a12
#define TFT_SCK 13 //a13
#define TFT_DC 10
#define TFT_CS 9
#define TFT_RST 8
#define C_BLACK 0x0000
#define C_BLUE 0x001F
#define C_RED 0xF800
#define C_GREEN 0x07E0
#define C_CYAN 0x07FF
#define C_MAGENTA 0xF81F
#define C_YELLOW 0xFFE0
#define C_WHITE 0xFFFF
#define PIN 7
#define NUMPIXELS 64
///Function CountDownTimer
int PWMValue = 0;
const byte buttonPin = 2;
byte menuCount = 1;
byte IntCount = 1;
byte HoldCount = 1;
byte dir = 0;
bool runState = false;
bool runState2 = false;
long oldPosition = -255;
long newPosition = 0;
long Position;
long oldPWMPosition = -100;
long PWMPosition = 1;
unsigned long Days = 1;
unsigned long Hours = 0;
unsigned long Minutes = 0;
unsigned long Seconds = 0;
signed long Sec = 0;
unsigned long startTime;
unsigned long oneSecond = 1000UL;
int awake;
/* Teensy3.2 Pins
FTM0 5, 6, 9, 10, 20, 21, 22, 23 488.28 Hz
FTM1 3, 4 488.28 Hz
FTM2 25, 32 488.28 Hz
unsigned int RED = 0;
unsigned int BLUE = 0;
unsigned int GREEN = 0;
unsigned int INTENSITY = 0;
unsigned int ON_Time1 = 0; // default
unsigned int OFFTime1 = 0;// default
//maybe make this new... with buttonevents
unsigned int count = 0; // how many times has it changed to low
unsigned long countAt = 0; // when count changed
unsigned int countPrinted = 0;
unsigned int icount = 0; // how many times has it changed to low
unsigned long icountAt = 0; // when count changed
unsigned int icountPrinted = 0;
//Function Interval Timer
int ON_LT3760 = LOW;
int minimumLT3760 = 10; //minimum pwm width needed to switch on off the lt3760
unsigned long PreviousMillis = 0;
unsigned long nowMillis;//important
elapsedMillis ElapsedOFF;
elapsedMillis ElapsedON;
int repeats = 1;
int Intensity = 0;
int i = 0;
int Readout_pinA10;
Adafruit_ST7735 tft = Adafruit_ST7735(TFT_CS, TFT_DC, TFT_RST);
FlickerFreePrint<Adafruit_ST7735> Data2(&tft, C_WHITE, C_BLACK);
Encoder Timer_1(3, 4);
Adafruit_NeoPixel pixels = Adafruit_NeoPixel(NUMPIXELS, PIN, NEO_GRB + NEO_KHZ800); //led matrix cjmcu-8x8
float j;
unsigned long StartTime, EndTime;
char str[30];
elapsedMillis msecs;
// 10 ms debounce
ADC *adc = new ADC(); // adc object
ButtonEvents myButton;
//SPI connection ST7735
pixels.begin();
pinMode(buttonPin, INPUT_PULLUP);
myButton.attach(buttonPin);
myButton.activeHigh();
myButton.debounceTime(15); //apply 15ms debounce
myButton.doubleTapTime(250);//apply 250ms Double click detection
myButton.holdTime(2000); // require button to be held for 2000ms before triggering a hold event
pixels.begin();
pinMode(6, OUTPUT); //SHDN Not Pin, switch on the LT3760
//analogPin for switching between UV to IR current limitation.
tft.initR(INITR_BLACKTAB);
tft.setRotation(4);
tft.fillScreen(C_BLACK);
tft.setTextSize(1);
tft.fillRect(0, 0, 150, 5, C_RED);
//Menu0
tft.setCursor(5, 10);
tft.print("Days");
//Menu1
tft.setCursor(5, 20);
tft.print("Hours");
//Menu2
tft.setCursor(5, 30);
tft.print("Minutes");
//Menu3
tft.setCursor(5, 40);
tft.print("Seconds");
//Menu4
tft.setCursor(5, 50);
tft.print("OFFTime");
//Menu5
tft.setCursor(5, 60);
tft.print("ONTime ");
//Menu5
tft.setCursor(5, 70);
tft.print("RED ");
//Menu6
tft.setCursor(5, 80);
tft.print("GREEN ");
//Menu7
tft.setCursor(5, 90);
tft.print("BLUE ");
//Menu8
tft.setCursor(5, 100);
tft.print("INTENSITY");
Menu1Check();
Menu1Countdown();
//this one is important because it controls all the menus
//read PWM Timer_1oder
int Menu1Check()
if (myButton.update() == true)
switch (myButton.event())
// things to do if the button was tapped (single tap)
case (tap) :
Serial.print("Single Click event detected = ");
menuCount = menuCount + 1;
Serial.print("MenuCountUp = ");
//(menuCount);
case (doubleTap) : //double click function move back in menu-1
Serial.print(" DOUBLE-TAP event detected ");
menuCount = menuCount - 1;
Serial.print(" DB TAP Count Down ");
//(menuCount);
case (hold) :
Serial.println("HOLD event detected");
HoldCount = HoldCount + 1; //To activate timer.
//limit the menu, Timer_1oder buttonpin
if (menuCount > 13)
{ Serial.print("menu larger as 10");
menuCount = 0;
if (menuCount == 1)
Serial.println("Menu1");
if (oldPosition >= 0 && oldPosition <= 255)
oldPosition = 0;
newPosition = Timer_1.read();
newPosition = newPosition / 4;
if (newPosition != oldPosition) //overwrite value compare with previous value
oldPosition = newPosition;
else //everything that is beyond the oldPosition or not equal to newPosition
Timer_1.write(0);
if (newPosition > 0 && newPosition < 30)
Days = newPosition;
Days = 1;
if (menuCount == 2)
Serial.println("Menu2");
oldPosition = 0;
Timer_1.write(0);
if (newPosition > 0 && newPosition < 59)
Hours = newPosition;
Hours = 12;
if (menuCount == 3)
{ Serial.print("Menu3");
oldPosition = 0;
Timer_1.write(0);
if (newPosition > 0 && newPosition < 99)
Minutes = newPosition;
Minutes = 0;
if (menuCount == 4)
{ Serial.print("Menu7");
oldPosition = 0;
Timer_1.write(0);
Seconds = newPosition;
Seconds = 0;
if (menuCount == 5)
Serial.println("set timer 1");
Timer_1.write(0);
if (menuCount == 6)
oldPosition = 0;
Timer_1.write(0);
if (newPosition > 0 && newPosition < 255)
OFFTime1 = (newPosition * 100);
OFFTime1 = 20000;
if (menuCount == 7)
oldPosition = 0;
Timer_1.write(0);
ON_Time1 = newPosition * 100; //Default value if new Position is not pressed
ON_Time1 = 10000;
if (menuCount == 8)
if (oldPosition >= 0 && oldPosition < 255)
oldPosition = 0;
} else //everything that is beyond the oldPosition or not equal to newPosition
Timer_1.write(0);
RED = newPosition;
//RED = constrain(RED, 0, 255);
RED = 0;
if (menuCount == 9)
oldPosition = 0;
Timer_1.write(0);
GREEN = newPosition;
// GREEN = constrain(GREEN, 0, 255);
GREEN = 247;
if (menuCount == 10)
oldPosition = 0;
Timer_1.write(0);
BLUE = newPosition;
} else
BLUE = 255;
if (menuCount == 11)
oldPosition = 0;
Timer_1.write(0);
INTENSITY = newPosition;
} else
INTENSITY = 255;
if (menuCount == 12)
//start timer
Serial.println(" starting Timer");
if (menuCount == 13)
//set repeats how many?
//loop Timer 1
Serial.print("condition T2 has ended, Back To Timer 1 which Menu = ");
Serial.print(menuCount);
menuCount = 1;
PWMValue = 1;
///////////////////////////////////////end of MenuInterval
//Display with Menu function u8g2
//countdown menu screen
int Menu1Countdown() //Menu 1
// fill to the end of field with background color.
// menus on the display: giving in Values, other static text is in void setup
if (menuCount > 0 && menuCount == 1)
{ pixels.clear();
tft.setCursor(70, 10);
Data2.print(Days);
if (menuCount > 1 && menuCount == 2)
tft.setCursor(70, 20);
Data2.print(Hours);
if (menuCount > 3 && menuCount == 4)
tft.setCursor(70, 30);
Data2.print(Minutes);
if (menuCount > 4 && menuCount == 5)
tft.setCursor(70, 40);
Data2.print(Seconds);
if (menuCount > 5 && menuCount == 6)
tft.setCursor(70, 50);
Data2.print(OFFTime1);
if (menuCount > 6 && menuCount == 7)
tft.setCursor(70, 60);
Data2.print(ON_Time1);
//tft.fillRect(x_text_cursor, 25, 40, 25, C_BLACK);
if (menuCount > 7 && menuCount == 8)
tft.setCursor(70, 70);
Data2.print(RED);
if (menuCount > 8 && menuCount == 9)
tft.setCursor(70, 80);
Data2.print(GREEN);
if (menuCount > 9 && menuCount == 10)
tft.setCursor(70, 90);
Data2.print(BLUE);
if (menuCount > 10 && menuCount == 11)
tft.setCursor(70, 100);
tft.setTextSize(1);
Data2.print(INTENSITY);
tft.setCursor(1, 110);
tft.setTextSize(2);
tft.println("Press -->");
// tft.setCursor(5, 120);
// tft.println(" Start");
Sec = round(Seconds * 1) + round(60 * Minutes) + round(60 * 60 * Hours) + round(60 * 60 * 24 * Days);
if (menuCount > 11 && menuCount == 12)
pixels.clear();
if (millis() - startTime >= oneSecond)
startTime += oneSecond;
if (Sec < 0)
Sec = 0;
/// blink during the menuCount check later on Countdown Zero or not Jump to MenuCount 1
if ((ON_LT3760 == HIGH) && (ElapsedOFF >= OFFTime1)) //OFFTime first
ON_LT3760 = LOW;
// ElapsedOFF=ElapsedOFF-OFFTime1;
for (int i = 0; i < NUMPIXELS; i++)
// pixels.Color takes RGB values, from 0,0,0 up to 255,255,255
pixels.setPixelColor(i, pixels.Color(RED, GREEN, BLUE)); // Moderately bright BLUE
pixels.setBrightness(50);
pixels.show(); // This sends the updated pixel color to the hardware.
//delay(delayval);
ElapsedOFF = 0; ElapsedON = 0;
// tft.setRotation(4);
tft.fillRect(110, 145, 10, 10, C_RED);
else if ((ON_LT3760 == LOW) && (ElapsedON >= ON_Time1)) //ONTime Second
ON_LT3760 = HIGH;
// delay(OFFTime1+minimumLT3760);
//digitalWrite(6, HIGH);
tft.fillRect(110, 130, 10, 10, C_RED);
// delay(ON_Time1+minimumLT3760);
{ // For each pixel...
pixels.setPixelColor(i, pixels.Color(0, 0, 0));
pixels.show();
pixels.clear();
if (ON_LT3760 == LOW) tft.fillRect(110, 145, 10, 10, C_YELLOW); //blinking boxes depended on high low state Interval
else tft.fillRect(110, 130, 10, 10, C_BLUE);
Days = Sec / 86400;
Hours = Sec / 3600;
Minutes = Sec / 60;
Seconds = Sec % 60;//end of countdown
//check countdown on Zero.
tft.setTextSize(2);
tft.setCursor(5, 130); //this cannot be positioned in the TimehasChanged if statement,
//this is because the screen works with a different update on the screen. it will freeze over.
// Serial.println(" R T1 ");
Data2.print((Hours % 60) % 60);
tft.print(":");
Data2.print(Minutes % 60);
tft.print(":");
Serial.print((Hours % 60) % 60);
Serial.print(":");
Serial.print(Minutes % 60);
Serial.print(":");
Serial.print(Seconds);
Serial.println("end");
Sec--;
if (menuCount > 12 && menuCount == 13)
digitalWrite(14, LOW); // digitalWrite(20,LOW);digitalWrite(19,HIGH);
// remove all cursors clear all values on screen
tft.setTextColor(ST7735_WHITE, ST7735_BLACK);
tft.print(" "); //Hours
tft.print(" "); //Minutes
tft.print(" "); //Seconds
tft.print(" "); //Offtime
tft.print(" "); //Ontime
tft.print(" "); //Red
tft.print(" "); //Green
tft.print(" "); //Blue
tft.print(" "); //Intensity
tft.setTextSize(2);
tft.println(" "); //Press-->
tft.setTextSize(2);
tft.print(" "); //Hours:Minutes:Seconds
menuCount = 1;
tft.setTextSize(1);
tft.setCursor(5, 150 ); //just a symbol to show where I am in the Menu
Data2.print(menuCount);
