Hi, I am trying to read SBUS with Teensy 4.0, the code has been working fine on teensy 3.2. There could be something else wrong also, but should Teensy 4.0 support Serial3.begin(100000, SERIAL_8E1_RXINV_TXINV); ?
In here https://www.pjrc.com/teensy/td_uart.html it says
Serial1.begin(baud, format)
Initialize the serial object with a baud rate and data format. Supported only on Teensy LC, 3.0, 3.1, 3.2, 3.5, 3.6.
But found on forum also that it should support and gives no error. (but does not work)
