Hello!
This is my first post to the forum, so apologies if I get something wrong with the format. I am hoping to get help figuring out why I am unable to control a Dolby CP750 Cinema Processor over Serial RS232 (D-Sub 9 pin). I think I am close (since I am able to receive data and print it out in the Serial Monitor, but sending data seems to be my problem.
Some quick background:
I am programing a Teensy LC in the Arduino IDE and am using a Sparkfun RS232 transceiver module. When I power up the Dolby I receive a bunch of serial status data, but when I try to send a command nothing happens.
My setup looks a bit like this (excerpt):
And a snippet from my loop looks like this:
Some specifications from the Dolby manual:
* Full control of the CP750 is available through a set of ASCII commands and queries. No error correction (CRC), sync bytes, or protocol is applied to this interface.
* The RS-232 connector supports standard 9‐pin serial connections to PC serial ports and other RS‐232 devices. It operates at 9600 baud with 8 data bits, 1 stop bit, no parity, and no flow control. It cannot be invoked while the serial data port is in use by the CP750 setup program.
I'd be happy to supply more info and details, but I don't want to overwhelm possible readers...
What have I tried so far?
1) I tried using both
and
2) I probed the Tx line with my DSO and was able to decode the serial commands easily. It looked like the logic level coming out of the max232 module was from zero to +12 volts.
3) In starting the Serial object I've tried the following:
4) I contacted Dolby and received a circuit diagram on the unit's serial port, but that didn't tell me what the minimum voltage threshold is.
Please let me know if you have any ideas!
#define CP750 Serial2
String rs232RX = 0;
CP750.begin(9600, SERIAL_8N1);
CP750.print("cp750.sys.input_mode dig_1");
Serial.print("Tx Cp750: ");
Serial.println("cp750.sys.input_mode dig_1");
Serial.write();
Serial.print();
CP750.begin(9600, SERIAL_8N1_RXINV);
CP750.begin(9600, SERIAL_8N1_TXINV);
CP750.begin(9600, SERIAL_8N1_RXINV_TXINV);
