Hello friend!
I have a little big problem with the i2c bus and various PCF chips. Specifically I have 3 chips with addresses 0x38, 0x39 and 0x3b. They are detected correctly, but when I run the code it seems that it is stuck when it finishes writing to the i2c bus.
I show you my code here:
This run in Setup, also run a scan for i2c devices. This is show by terminal:
But not show "Init PCF8574s finished."...
Library: https://github.com/xreef/PCF8574_library
Any solution?
Regards
void initPCF() {
#if DEBUG==true
Serial.println("Starting PCF8574s for LEDs");
pcf8574_av.pinMode(P0, OUTPUT, HIGH);
pcf8574_av.pinMode(P1, OUTPUT, HIGH);
pcf8574_av.pinMode(P2, OUTPUT, HIGH);
pcf8574_av.pinMode(P3, OUTPUT, HIGH);
pcf8574_av.pinMode(P4, OUTPUT, HIGH);
pcf8574_av.pinMode(P5, OUTPUT, HIGH);
pcf8574_av.pinMode(P6, OUTPUT, HIGH);
pcf8574_av.pinMode(P7, OUTPUT, HIGH);
#if DEBUG==true
Serial.print("Init pcf8574 availables...");
if (pcf8574_av.begin()){
#if DEBUG==true
Serial.println("OK");
}else{
#if DEBUG==true
Serial.println("KO");
pcf8574_fail.pinMode(P0, OUTPUT);
pcf8574_fail.pinMode(P1, OUTPUT);
pcf8574_fail.pinMode(P2, OUTPUT);
pcf8574_fail.pinMode(P3, OUTPUT);
pcf8574_fail.pinMode(P4, OUTPUT);
pcf8574_fail.pinMode(P5, OUTPUT);
pcf8574_fail.pinMode(P6, OUTPUT);
pcf8574_fail.pinMode(P7, OUTPUT);
#if DEBUG==true
Serial.print("Init pcf8574 fails...");
if (pcf8574_fail.begin()){
#if DEBUG==true
}else{
#if DEBUG==true
pcf8574_en.pinMode(P0, OUTPUT);
pcf8574_en.pinMode(P1, OUTPUT);
pcf8574_en.pinMode(P2, OUTPUT);
pcf8574_en.pinMode(P3, OUTPUT);
pcf8574_en.pinMode(P4, OUTPUT);
pcf8574_en.pinMode(P5, OUTPUT);
pcf8574_en.pinMode(P6, OUTPUT);
pcf8574_en.pinMode(P7, OUTPUT);
#if DEBUG==true
Serial.print("Init pcf8574 enables...");
if (pcf8574_en.begin()){
#if DEBUG==true
}else{
#if DEBUG==true
#if DEBUG==true
Serial.println("Init PCF8574s finished.");
Scanning...
Device found at address 0x38 (RA8875,FT6206,MAX98390)
Device found at address 0x39 (TSL2561, APDS9960)
Device found at address 0x3B (unknown chip)
done
Init pcf8574 availables...OK
Init pcf8574 fails...OK
Init pcf8574 enables...OK
Any solution?
Regards
