Results 1 to 2 of 2
Thread: Demo code: T4.1 USB Host keyboard, Moog Ladder Filter, Flange, Plate Reverb
    1,689
    Here's a demo sketch which uses a USB MIDI keyboard on a T4.1 USB host to play
    notes from the Moog Ladder Filter through the flanger effect and Plate Reverb.
    The platereverb library is included with the sketch.
    The ladderfilter2 library must be installed in the Audio library in your
    local libraries/Audio directory.
    The ladderfilter2 code is at: https://github.com/ddiakopoulos/MoogLadders
    Pete
    LadderFilter_platerev_41.zip
    1,689
    Minor correction. I was sending the left channel of the reverb to left and right outputs. The last connection should be this:
    AudioConnection          patchCordb(reverb, 1, i2s1, 1);
    Pete
