Hello Teensys
I am working on project that involves the audio and the wire library. I have connected a generic OLED I2C display to my teensy audio project in order to display some information about what the teensy is doing. When I update the display the audio cuts out. If I put the display.display() function in the main loop I get almost no audio. If I make the display update every few hundred milliseconds I can hear the audio cut out every time the display updates. I have done some goggling on this subject and it looks like the teensy can not do anything else while its sending data out to the I2C bus. It looks like the same issue is described in this post
https://forum.pjrc.com/threads/49187-OLED-updating-slowing-down-motors
Bellow is my troubleshooting code. I am using a Teensy 4.1 with a Adafruit I2S Stereo Decoder UDA1334A and a SSD1306 128x64 OLED display.
I have tied using different I2C bus on the Teensy pins 18, 19 and pins 16, 17 and it did not help. I tried using the wire library and the i2c_t3 library and the end result is the same.
I have watched the audio library demo video on youtube and the last part they have a display showing the audio level in real time with no audio interruption at all using a SPI display. I understand i2c is a slower protocol but is there not no way to use i2c without pausing all other code?
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
#define OLED_RESET 4
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire1, OLED_RESET);
AudioSynthWaveform waveform1; //xy=285,305
AudioEffectEnvelope envelope1; //xy=487,307
AudioEffectEnvelope envelope2; //xy=491,371
AudioFilterStateVariable filter1; //xy=743,450
AudioAmplifier amp1; //xy=903,444
AudioOutputI2S i2s1; //xy=1094,439
AudioConnection patchCord1(waveform1, envelope1);
AudioConnection patchCord2(waveform1, envelope2);
AudioConnection patchCord3(envelope1, 0, filter1, 0);
AudioConnection patchCord4(envelope2, 0, filter1, 1);
AudioConnection patchCord5(filter1, 0, amp1, 0);
AudioConnection patchCord6(amp1, 0, i2s1, 0);
AudioConnection patchCord7(amp1, 0, i2s1, 1);
//Global Variables
const float noteFreqs[128] = {8.176, 8.662, 9.177, 9.723, 10.301, 10.913, 11.562, 12.25, 12.978, 13.75, 14.568, 15.434, 16.352, 17.324, 18.354, 19.445, 20.602, 21.827, 23.125, 24.5, 25.957, 27.5, 29.135, 30.868, 32.703, 34.648, 36.708, 38.891, 41.203, 43.654, 46.249, 48.999, 51.913, 55, 58.27, 61.735, 65.406, 69.296, 73.416, 77.782, 82.407, 87.307, 92.499, 97.999, 103.826, 110, 116.541, 123.471, 130.813, 138.591, 146.832, 155.563, 164.814, 174.614, 184.997, 195.998, 207.652, 220, 233.082, 246.942, 261.626, 277.183, 293.665, 311.127, 329.628, 349.228, 369.994, 391.995, 415.305, 440, 466.164, 493.883, 523.251, 554.365, 587.33, 622.254, 659.255, 698.456, 739.989, 783.991, 830.609, 880, 932.328, 987.767, 1046.502, 1108.731, 1174.659, 1244.508, 1318.51, 1396.913, 1479.978, 1567.982, 1661.219, 1760, 1864.655, 1975.533, 2093.005, 2217.461, 2349.318, 2489.016, 2637.02, 2793.826, 2959.955, 3135.963, 3322.438, 3520, 3729.31, 3951.066, 4186.009, 4434.922, 4698.636, 4978.032, 5274.041, 5587.652, 5919.911, 6271.927, 6644.875, 7040, 7458.62, 7902.133, 8372.018, 8869.844, 9397.273, 9956.063, 10548.08, 11175.3, 11839.82, 12543.85};
byte globalNote = 0;
byte globalVelocity = 0;
long previousMillis = 0;
bool envelope_state = true;
int PlayingNote = 60;
long DisplayRefresh = 0;
Wire1.begin();
display.begin(SSD1306_SWITCHCAPVCC, 0x3C);
Wire1.setClock(400000);
display.clearDisplay();
display.display();
AudioMemory(300);
waveform1.begin(WAVEFORM_SQUARE);
waveform1.amplitude(0.75);
waveform1.frequency(440);
waveform1.phase(0);
envelope1.attack(50);
envelope1.decay(5);
envelope1.sustain(1.0);
envelope1.release(250);
envelope2.delay(0);
envelope2.hold(0);
filter1.octaveControl(7.0);
filter1.resonance(2.0);
envelope1.noteOn();
envelope2.noteOn();
waveform1.frequency(noteFreqs[PlayingNote]);
unsigned long currentMillis = millis();
if (currentMillis - DisplayRefresh > 750) {
DisplayRefresh = currentMillis;
UserDisplay();
} // end of main loop
void UserDisplay(){
display.setTextColor(WHITE);
display.setTextSize(1);
display.setCursor(0,0);
display.print("Teensy Bass");
display.setTextSize(2);
display.setCursor(0,24);
display.print("Note ");
display.print(PlayingNote);
display.display();
