Troubleshooting RAM overflow (crosspost)
faemagedon
New member
Hi I've been trying to run a library made with the faust IDE and keep getting this error on Teensy 3.5:
I'm using teensyduino as the IDE and including faust library.
Arduino: 1.8.13 (Mac OS X), TD: 1.53, Board: "Teensy 3.5, Serial, 120 MHz, Faster, US English"
/Applications/Teensyduino.app/Contents/Java/hardware/tools/arm/bin/../lib/gcc/arm-none-eabi/5.4.1/../../../../arm-none-eabi/bin/ld: /var/folders/xw/4_chkj0n4w58bfhrx_pb57pm0000gn/T/arduino_build_415137/sketch_may06a.ino.elf section `.bss' will not fit in region `RAM'
/Applications/Teensyduino.app/Contents/Java/hardware/tools/arm/bin/../lib/gcc/arm-none-eabi/5.4.1/../../../../arm-none-eabi/bin/ld: region `RAM' overflowed by 41148 bytes
collect2: error: ld returned 1 exit status
Used: /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SD
Not used: /Applications/Teensyduino.app/Contents/Java/libraries/SD
Error compiling for board Teensy 3.5.
The code is as follows:
#include "AMSmallSynth.h"
AMSmallSynth      waveform1;      //xy=345,257
AudioOutputAnalogStereo  dacs1;          //xy=577,253
AudioConnection          patchCord1(waveform1, 0, dacs1, 0);
AudioConnection          patchCord2(waveform1, 0, dacs1, 1);
AudioControlSGTL5000     audioShield;     //xy=383,373
int buttonPinsOrange[] = {24, 25 ,26, 27};
int buttonPinsBlue[] = {28, 29, 30, 31};
byte currentPressOrange = 0;
byte currentPressBlue = 0;
int ledPinsBlue[] = {36, 37, 38, 39};
int ledPinsOrange[] = {32, 33, 34, 35};
float activeFrequency;
float octaveMultiplier = 1;
//float fundementals[] = {220, 220, 233.08, 246.94, 261.6, 277.18, 293.67, 311.13, 329.63, 349.23, 369.99, 392, 415.3, 440, 220, 220};
  for(int i = 0; i < 4; i++){
    pinMode(buttonPinsOrange[i],OUTPUT);
    pinMode(buttonPinsBlue[i],OUTPUT);
    pinMode(ledPinsBlue[i], OUTPUT);
    pinMode(ledPinsOrange[i], OUTPUT);
  AudioMemory(127);
  audioShield.enable();
  audioShield.volume(0.1);
  waveform1.setParamValue("gain",0.9);
//  verb1.roomsize(0.2);
//  verb1.damping(0.7);
  //waveform1.setParamValue("duration",0.250);
 currentPressOrange = readButtonPins(buttonPinsOrange);
 currentPressBlue = readButtonPins(buttonPinsBlue);
 writeLeds(currentPressBlue, currentPressOrange);
 if (currentPressOrange == 0) {
  activeFrequency = 0;
  waveform1.setParamValue("trigger",0);
  activeFrequency = octaveMultiplier * (fundementals[currentPressBlue]*pow(2,((currentPressOrange)-1)/12.));
  waveform1.setParamValue("trigger",1);
 waveform1.setParamValue("car_freq",activeFrequency);
 while (currentPressOrange == 14) {
      octaveMultiplier *= 2;
  while (currentPressOrange == 15){
    octaveMultiplier *= 0.5;
  delay(50);
byte readButtonPins(int buttonPinsArr[]) {
  byte r_press = 0;
    if (digitalRead(buttonPinsArr[i]) == HIGH){
      bitWrite(r_press,i,1);
      bitWrite(r_press,i,0);
  return r_press;
void writeLeds(byte blue_press, byte orange_press){
    digitalWrite(ledPinsBlue[i],bitRead(blue_press,i));
    digitalWrite(ledPinsOrange[i],bitRead(orange_press,i));
Any suggestions as to what I could do to remedy this error?
Sorry, there is almost nothing shown here to know where your memory is being used.
Also I don't know what it means to say library made with the faust IDE...
But it does sound like either:
a) there are some very large buffers defined like: uint8_t myBuffer[250000];
Or lots of little ones that add up:
b) Or lots of tables that were defined that are eating up memory.
Like uint8_t mySoundslist[] = {0,0,........ lots and lots of values};
These like tables are downloaded to RAM at startup time. These can be resolved my specifying the table as const
const uint8_t myTable[] = {.......};
These are left in program in the FLASH memory and don't eat up RAM...
Note on T4.x you also need to specify DMAMEM as well.
