Results 1 to 6 of 6
Thread: Teensy 4.1 usb audio out. How?
    I try to get my Teensy 4.1 to output audio to usb.
    The following code doesn't work. Teensy appears as usb audio device on MacOS, but I can't hear any white noise when I select it's input.
    //#include <SPI.h>
    //#include <SD.h>
    //#include <SerialFlash.h>
    AudioSynthNoiseWhite     noise1;         //xy=164,557AudioOutputUSB
    AudioOutputUSB           usb1;           //xy=370,519
    AudioConnection          patchCord1(noise1, 0, usb1, 0);
    AudioConnection          patchCord2(noise1, 0, usb1, 1);
    //used to blink the led to show that something is happening
    int led=13;
      AudioMemory(80);
      pinMode(led, OUTPUT);
    Jul 2020
    1,042
    You need to include at least one audio object that generates a clock, for instance AudioInputI2S or AudioOutputI2S.
    Without a clocked object nothing ever happens.
    Apr 2021
    Cambridgeshire, UK
    62
    Also, as I found out last night, you need to set the noise generator going by setting its amplitude to a non-zero value...
    thanks. I got it working. I think it would make sense to include a example in teensyduino.
    24,270
    Quote Originally Posted by flocked View Post
    File > Examples > Audio > HardwareTesting > WavFilePlayerUSB
    Ah perfect. I was searching for it. Maybe rename it it to WavFilePlayerUSBOutput?
