Results 1 to 2 of 2
Thread: How do I save the Audio data to the SD Card?
    Question on saving Audio data to the SD Card on Teensy 4.1
    There is a conflict when I #include "SdFat-beta.h" and #include <Audio.h>.
    Here is the SD card code, and it works.
    SdExFat sd;
    if (!sd.begin(SdioConfig(FIFO_SDIO))) { // SdFat.h Ver 2.0.0 Beta
    Serial.println("m.SD initialization failed!");
    Serial.println("m.SD initialization OK");
    auto file = sd.open("data.txt", FILE_WRITE);
    file.write("123");
    file.close();
    But when I include <Audio.h>, there is a warning: "FILE_READ" redefined
    #define FILE_READ O_READ
    warning: "FILE_WRITE" redefined
    #define FILE_WRITE (O_READ | O_WRITE | O_CREAT)
    error: using typedef-name 'File' after 'class'
    class File : public Stream {
    3,159
    with latest TD (1.54b7) you do NOT include SdFat-beta, but you use SD.h, which is now an interface to SdFat-V2 (prev SdFat-beta)
