Results 1 to 1 of 1
Thread: Multiple libraries were found
    Jan 2021
    5
    I have been working on a drone project for last 4 months and even though within this period never saw this error, after I updated the libraries or bought a new teensy 3.6 (these happened at the same time) the problem - Multiple libraries were found for "Servo.h" - showed up and I cannot solve it. I saw a post about this and I applied the things that mentioned in it but still could not solve it. There was servo library in Documents\Arduino\libraries and I deleted it but still same error and also -undefined reference to `_write' - added. I would be grateful if someone could help me. Thank you.
    Here is the full error:
    Arduino: 1.8.13 (Windows 10), TD: 1.53, Board: "Teensy 3.6, Serial, 180 MHz, Faster, US English"
    c:/program files (x86)/arduino/hardware/tools/arm/bin/../lib/gcc/arm-none-eabi/5.4.1/../../../../arm-none-eabi/lib/armv7e-m/fpu\libc.a(lib_a-writer.o): In function `_write_r':
    writer.c.text._write_r+0x12): undefined reference to `_write'
    Used: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Servo
    Not used: C:\Program Files (x86)\Arduino\libraries\Servo
    Error compiling for board Teensy 3.6.
    and here is the code. This is one of the several tabs only one with servo:
    #include <Servo.h>
    Servo frontLeftMotor;
    Servo frontRightMotor;
    Servo rearLeftMotor;
    Servo rearRightMotor;
    void initializeMotors() {
      frontLeftMotor.attach(FRONT_LEFT_MOTOR_PIN, MIN_MOTOR_PULSE_WIDTH, MAX_MOTOR_PULSE_WIDTH);
      frontRightMotor.attach(FRONT_RIGHT_MOTOR_PIN, MIN_MOTOR_PULSE_WIDTH, MAX_MOTOR_PULSE_WIDTH);
      rearLeftMotor.attach(REAR_LEFT_MOTOR_PIN, MIN_MOTOR_PULSE_WIDTH, MAX_MOTOR_PULSE_WIDTH);
      rearRightMotor.attach(REAR_RIGHT_MOTOR_PIN, MIN_MOTOR_PULSE_WIDTH, MAX_MOTOR_PULSE_WIDTH);
      stopMotors();
    void spinMotors(struct MotorPowers motorPowers) {
      frontLeftMotor.write(motorPowers.frontLeftMotorPower);
      frontRightMotor.write(motorPowers.frontRightMotorPower);
      rearLeftMotor.write(motorPowers.rearLeftMotorPower);
      rearRightMotor.write(motorPowers.rearRightMotorPower);
    void stopMotors() {
      frontLeftMotor.write(0);
      frontRightMotor.write(0);
      rearLeftMotor.write(0);
      rearRightMotor.write(0);
