4.1 - NativeEthernet - Ethernet.begin hangs program
MartinJR
I am wondering whether anyone can help please. Using NativeEthernet on a 4.1 results in 'Ethernet.begin()' hanging the program. Using Ethernet.Begin in DHCP or full IP mode makes no difference. I haven't got a 'shield' or live socket attached, it's just the Teensy on its own. I am also using an SD card but whether present or not has no effect.
Ethernet.begin(m_serverMacc, m_serverip, m_dnsserver, m_gateway, m_subnet);
I am getting the MAC from the Teensy using https://forum.pjrc.com/threads/57595-Serial-amp-MAC-Address-Teensy-4-0 and that seems to be functioning fine. Can anyone suggest things I need to research, or indeed, has anyone else had this problem?
It only happens when using the NativeEthernet library, not the standard Ethernet one.
Thanks.
It's normal. If you do not have a cable connected it will hang forever.
You can see it on line 293. I believe it was left that way to be consistent with the original Ethernet library but you can comment it out which is the solution I used in my project.
https://github.com/vjmuzik/NativeEthernet/blob/master/src/NativeEthernet.cpp#L293
Here is vjmuzik's explanation. I do wish there was a better solution as I do not like modifying libraries and having to worry about updates.
https://forum.pjrc.com/threads/65653-non-blocking-Ethernet-begin()-with-cable-disconnected-amp-static-IP?p=265000&viewfull=1#post265000
Thanks for that. What a gotcha!
Yeah, editing libraries is never a good idea but I have a similar issue to K7MDL - the application needs to keep running regardless of a connection. Interestingly, the oridinary ethernet library doesn't have this problem, although maybe something else is happening instead!
