Page 3 of 3 FirstFirst 1 2 3
Results 51 to 59 of 59
Thread: Teensyduino 1.54 Beta #8
  1. #51
    9,219
    Yes, confirmed, I am able to reproduce the memcpy bug. Working on it now....
    I also have no idea. I didn't change it. Committed a fix to never use unaligned access.
    https://github.com/PaulStoffregen/co...71d93dace89f91
    But this alone is not enough to solve the problem. Looks like gcc is sometimes replacing "memcpy" with "__builtin_mempy", which also seems to do unaligned access. I'm trying different fixes now....
    I know I should and probably will look it up, but what does: -mno-unaligned-access
    do?
    That is what does this do when you have structures defined with with __attribute__((packed))
    and the items are not aligned?
  2. #52
    1,527
    @luni
    Followed the instructions to install arm9 (installed the 9-2020-q2-update) and changed the following in the boards.txt file to
    #teensy41.build.toolchain=arm/bin/
    teensy41.build.toolchain=arm9/bin/
    using IDE 1.8.14beta8 and then reran the example but it seems to work for me:
    first
    second
    answer
    only tested on a T4.1 though.
    EDIT: These are the instructions that I followed:
    Thanks for testing. I had a hard time reproducing the bug myself until I remembered that I "simplified" the test code before posting by replacing std::string with char*. Not a good idea because the char* version does compile indeed.
    Here the original test version which generates the compile errors mentioned above. Doesn't compile with Arduino 1.8.13, TD 1.54b7 and GCC9. Works with TD1.53 and GCC9. With GCC 5.4 (standard TD compiler) it works in any case. Works with GCC 9 if I unwind the core files changes before this commit: https://github.com/PaulStoffregen/co...04356bda7e2a7e
    #include <map>
    #include <string>
        while(!Serial){}
        std::map<int,std::string>m {{1,"first"}, {2,"second"}, {42,"answer"}};
        Serial.println(m[42].c_str());
    void loop(){
  3. #53
    7,224
    #include <map>
    #include <string>
        while(!Serial){}
    void loop(){
    Ok - just retested with 1.8.14b8 and 1.8.15b9 with GCC9 and yes it does fail to compile but as you said it compiles fine with the default gcc. Saw they GCC10 is out as well. So tempted.
  4. #54
    9,219
    I have the GCC9... And I do get a failure... Currently it looks like:
    "C:\\arduino-1.8.15\\hardware\\teensy/../tools/arm9/bin/arm-none-eabi-gcc" -O2 -Wl,--gc-sections,--relax "-TC:\\arduino-1.8.15\\hardware\\teensy\\avr\\cores\\teensy4/imxrt1062.ld" -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -o "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_553006/foo.ino.elf" "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_553006\\sketch\\foo.ino.cpp.o" "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_553006/core\\core.a" "-LC:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_553006" -larm_cortexM7lfsp_math -lm -lstdc++
    c:/arduino-1.8.15/hardware/tools/arm9/bin/../lib/gcc/arm-none-eabi/9.3.1/../../../../arm-none-eabi/bin/ld.exe: cannot find -larm_cortexM7lfsp_math
    Same with T4.1 Did I miss a step or is this the same error you are receiving?
  5. #55
    1,527
    You first need to copy the math libraries to the gcc folder as explained in the WIKI.
    Here the error messages I get. They are from the linker not from the compiler and are related to the changes in the linker script introduced in the referenced commit. I don't know if this is an issue introduced by GCC9 or if GCC 5.4 simply doesn't report the underlying problem.
    "C:\\Program Files\\Arduino\\arduino-1.8.13\\hardware\\teensy/../tools/arm9/bin/arm-none-eabi-gcc" -O2 -Wl,--gc-sections,--relax "-TC:\\Program Files\\Arduino\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy4/imxrt1062_t41.ld" -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -o "C:\\Users\\lutz\\AppData\\Local\\Temp\\arduino_build_844573/Blink.ino.elf" "C:\\Users\\lutz\\AppData\\Local\\Temp\\arduino_build_844573\\sketch\\Blink.ino.cpp.o" "C:\\Users\\lutz\\AppData\\Local\\Temp\\arduino_build_844573/core\\core.a" "-LC:\\Users\\lutz\\AppData\\Local\\Temp\\arduino_build_844573" -larm_cortexM7lfsp_math -lm -lstdc++
    c:/program files/arduino/arduino-1.8.13/hardware/tools/arm9/bin/../lib/gcc/arm-none-eabi/9.3.1/../../../../arm-none-eabi/lib/thumb/v7e-m+dp/hard\libstdc++.a(functexcept.o):(.ARM.exidx.text.unlikely._ZSt17__throw_bad_allocv+0x4): relocation truncated to fit: R_ARM_PREL31 against `.ARM.extab.text.unlikely._ZSt17__throw_bad_allocv'
    c:/program files/arduino/arduino-1.8.13/hardware/tools/arm9/bin/../lib/gcc/arm-none-eabi/9.3.1/../../../../arm-none-eabi/lib/thumb/v7e-m+dp/hard\libstdc++.a(functexcept.o):(.ARM.extab.text.unlikely._ZSt19__throw_logic_errorPKc+0x0): relocation truncated to fit: R_ARM_PREL31 against symbol `__gxx_personality_v0' defined in .text.__gxx_personality_v0 section in c:/program files/arduino/arduino-1.8.13/hardware/tools/arm9/bin/../lib/gcc/arm-none-eabi/9.3.1/../../../../arm-none-eabi/lib/thumb/v7e-m+dp/hard\libstdc++.a(eh_personality.o)
    c:/program files/arduino/arduino-1.8.13/hardware/tools/arm9/bin/../lib/gcc/arm-none-eabi/9.3.1/../../../../arm-none-eabi/lib/thumb/v7e-m+dp/hard\libstdc++.a(functexcept.o):(.ARM.exidx.text.unlikely._ZSt19__throw_logic_errorPKc+0x4): relocation truncated to fit: R_ARM_PREL31 against `.ARM.extab.text.unlikely._ZSt19__throw_logic_errorPKc'
    c:/program files/arduino/arduino-1.8.13/hardware/tools/arm9/bin/../lib/gcc/arm-none-eabi/9.3.1/../../../../arm-none-eabi/lib/thumb/v7e-m+dp/hard\libstdc++.a(functexcept.o):(.ARM.extab.text.unlikely._ZSt20__throw_length_errorPKc+0x0): relocation truncated to fit: R_ARM_PREL31 against symbol `__gxx_personality_v0' defined in .text.__gxx_personality_v0 section in c:/program files/arduino/arduino-1.8.13/hardware/tools/arm9/bin/../lib/gcc/arm-none-eabi/9.3.1/../../../../arm-none-eabi/lib/thumb/v7e-m+dp/hard\libstdc++.a(eh_personality.o)
    c:/program files/arduino/arduino-1.8.13/hardware/tools/arm9/bin/../lib/gcc/arm-none-eabi/9.3.1/../../../../arm-none-eabi/lib/thumb/v7e-m+dp/hard\libstdc++.a(functexcept.o):(.ARM.exidx.text.unlikely._ZSt20__throw_length_errorPKc+0x4): relocation truncated to fit: R_ARM_PREL31 against `.ARM.extab.text.unlikely._ZSt20__throw_length_errorPKc'
    c:/program files/arduino/arduino-1.8.13/hardware/tools/arm9/bin/../lib/gcc/arm-none-eabi/9.3.1/../../../../arm-none-eabi/lib/thumb/v7e-m+dp/hard\libstdc++.a(string-inst.o):(.ARM.exidx.text._ZNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEE9_M_createERjj[_ZNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEE9_M_createERjj]+0x4): relocation truncated to fit: R_ARM_PREL31 against `.ARM.extab.text._ZNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEE9_M_createERjj'
    c:/program files/arduino/arduino-1.8.13/hardware/tools/arm9/bin/../lib/gcc/arm-none-eabi/9.3.1/../../../../arm-none-eabi/lib/thumb/v7e-m+dp/hard\libstdc++.a(eh_catch.o):(.ARM.extab.text.__cxa_begin_catch+0x0): relocation truncated to fit: R_ARM_PREL31 against symbol `__gxx_personality_v0' defined in .text.__gxx_personality_v0 section in c:/program files/arduino/arduino-1.8.13/hardware/tools/arm9/bin/../lib/gcc/arm-none-eabi/9.3.1/../../../../arm-none-eabi/lib/thumb/v7e-m+dp/hard\libstdc++.a(eh_personality.o)
    c:/program files/arduino/arduino-1.8.13/hardware/tools/arm9/bin/../lib/gcc/arm-none-eabi/9.3.1/../../../../arm-none-eabi/lib/thumb/v7e-m+dp/hard\libstdc++.a(eh_catch.o):(.ARM.exidx.text.__cxa_begin_catch+0x4): relocation truncated to fit: R_ARM_PREL31 against `.ARM.extab.text.__cxa_begin_catch'
    c:/program files/arduino/arduino-1.8.13/hardware/tools/arm9/bin/../lib/gcc/arm-none-eabi/9.3.1/../../../../arm-none-eabi/lib/thumb/v7e-m+dp/hard\libstdc++.a(eh_personality.o):(.ARM.exidx.text._ZL21base_of_encoded_valuehP15_Unwind_Context+0x4): relocation truncated to fit: R_ARM_PREL31 against `.ARM.extab.text._ZL21base_of_encoded_valuehP15_Unwind_Context'
    c:/program files/arduino/arduino-1.8.13/hardware/tools/arm9/bin/../lib/gcc/arm-none-eabi/9.3.1/../../../../arm-none-eabi/lib/thumb/v7e-m+dp/hard\libstdc++.a(eh_personality.o):(.ARM.extab.text.__gxx_personality_v0+0x0): relocation truncated to fit: R_ARM_PREL31 against symbol `__gxx_personality_v0' defined in .text.__gxx_personality_v0 section in c:/program files/arduino/arduino-1.8.13/hardware/tools/arm9/bin/../lib/gcc/arm-none-eabi/9.3.1/../../../../arm-none-eabi/lib/thumb/v7e-m+dp/hard\libstdc++.a(eh_personality.o)
    c:/program files/arduino/arduino-1.8.13/hardware/tools/arm9/bin/../lib/gcc/arm-none-eabi/9.3.1/../../../../arm-none-eabi/lib/thumb/v7e-m+dp/hard\libstdc++.a(eh_personality.o):(.ARM.exidx.text.__gxx_personality_v0+0x4): additional relocation overflows omitted from the output
    Error compiling for board Teensy 4.1.
  6. #56
    9,219
    Thanks, I might be missing the copy of math libraries as I am building with Arduino and I only saw the copy of stuff mentioned under VisualTeensy
    But will take a look again
    Ooops - I installed in new directory... did not copy old one first ...
  7. #57
    1,527
    At the end both methods do the same. Either overwrite an existing copy with the new files or just copy the 4 missing math libraries to a new installation.
  8. #58
    9,219
    Thanks,
    I just redid it following the instructions... And now it fails the same way you mentioned
  9. #59
