Hello. I'm new to this forum and have a question about the serial monitor.
For Teensy 4.0/4.1 connected to Arduino IDE 1.8.13 on Windows 7 or 10, I can't seem to get the command history (i.e. use the arrow keys to scroll thru the previously-entered commands) when using the IDE's built-in serial monitor. Is this a limitation of Teensy's virtual serial port, or is smth wrong with my config ?
Interestingly, when I sub the Teensy with the Arduino DUE board in the exact same set-up, the command history works just fine !
Thanks much !
Thanks much !
