Aloha
I picked up my Teensy stuff again (working a DMX project) and came across an issue using the Arduino IDE Serial Monitor - it shows nothing.
My Teensy 3.2 has the USB power line cut (as 5v comes in via the OctoWS8211 board from a bench supply), if that makes any difference.
When my test sketches (Octo library Basic Example) didnt emit println statements, I fell back to making a trivial Hello World - stuck a Serail.println("Hello World") in the default empty setup() function. Build on Win10 in IDE 1.8.13, fed to Teensy using Loader 1.53. Open the Serial Monitor and nothing comes out.
As I understand Teensy, it does not require Serial.begin() when using the USB serial, correct?
So why isnt this working?
Serial.println("Hello World");
