Page 4 of 4 FirstFirst ... 2 3 4
Results 76 to 95 of 95
Thread: Teensyduino 1.54 Beta #9
  1. #76
    Mar 2015
    181
    On obvious serious errors like this, it should not warn but refuse to compile. The warnings I find not useful at all, super difficult to read with the long paths included.
  2. #77
    15,080
    Quote Originally Posted by Garug View Post
    Because of the 'enum' usage it sneaks past the compiler detection, so no warning.
    Using #defines for x,y,z,t would cause warnings.
    gcc compiler options can be added to call all warnings errors, but generally that is ugly as the various pieces of code from libs or other can make warnings on one build toolchain and not another. PJRC works to have few or no warnings in included libraries.
    This is more a non-PJRC 'religious' topic subject to preference and use cases, for instance see embeddedartistry.com/blog/2017/05/22/werror-is-not-your-friend/
  3. #78
    Mar 2021
    15
    NativeEthernet / FNET dns issue
    Quote Originally Posted by beermat View Post
    NativeEthernet for now appears unsupported (no activity on the forum or in the codebase for several months), which is a shame, because it's super useful, apart from a couple of minor issues like this.
    I aggree with @beermat and I'm astonished that so few people using @vjmuzik NativeEthernet are interested in this (as I think) important dns-client issue.
    RoSchmi
  4. #79
    Quote Originally Posted by RoSchmi View Post
    RoSchmi
    I'm certainly interested. Ethernet is a huge win on the T4.1 The chip actually supports 2 PHYs, would love to see a dual 10/100 teensy 4.2, but NativeEthernet needs some fixes.
  5. #80
    I'm also interested in any improvements to @vjmuzik NativeEthernet and the eventual merging of native ethernet support into TeensyDuino.
  6. #81
    15,080
    NativeEthernet
    NativeEthernet was provided by a user and included in TeensyDuino. Not sure about vjmuzik's time/ability to update or maintain. But the best way to have the library fixed/extended would be to post on that thread : pjrc.com/threads/60857-T4-1-Ethernet-Library
    Offer examples that work or should work and make appropriate PR's against the FNET or github.com/vjmuzik/NativeEthernet
  7. #82
    @defragster, point taken, and I agree with you. I was merely adding a voice to the comments by @beermat and @RoSchmi.
  8. #83
    Mar 2021
    15
    NativeEthernet
    Done.
    https://github.com/vjmuzik/FNET/pull/6
    It would be nice if some more experienced members than I would have a look on the changes.
  9. #84
    15,080
    Done.
    Awesome. Hopefully @vjmuzik is online to see and confirm and incorporate the changes.
    This thread will soon be history for Beta 10 and the release of TD 1.54 - so better to get the history and notes on the NativeEthernet thread noted in p#81
  10. #85
    146
    SDFat issue
    So I have a sketch that compiles in fine in Arduino 1.8.13/Teensyduino 1.53. So I just downloaded a clean copy of Arduino 1.8.15Teensyduino 1.54 beta #9 and I get compile errors.
    One was the FlexCAN_T4. I updated the library and the problem went away.
    Now I have one with SDFat. Again the Teensyduino library is out of date so I updated it to 2.0.6 which is the latest release.
    Still I get a compile error:
    'File' does not name a type
    File file;
    4_SDFuntions.h:33: error: 'File' does not name a type
    File wfile;//define write file to write header.
    I am including the same files as before:
    #include <SdFat.h>
    #include <sdios.h>
    SdFat sd;
    File file;
    This is really perplexing as to what would have changed between the two IDE sets to cause this error.
    Any thoughts?
    PS The SDFat example "ReadCsvFile" does not compile either and give me the same error.
    PSS So apparently
    SdFat32 sd;
    File32 file;
    File32 wfile;
    does name a type.
    Bruce
  11. #86
    15,080
    Quote Originally Posted by bvernham View Post
    #include <SdFat.h>
    Bruce
    When using TD 1.54 b9, or after, SdFat is included with the TeensyInstaller.
    Remove local copies of that library from build paths.
    SD.h has been reworked to map into SdFat.
    But the full SdFat library is included.
  12. #87
    146
    Actually the included SDFat library seem to be 1 step behind the github release.
    The issue is that all of a sudden "File" is not recognized but "File32" is so it sees the library but why is it ignoring "File"? Both the latest github release and the the packaged version of SDFat in 1.54 beta 9 have the same issue.
    If I specify Fat32 then there is no issue.
    Like I said with the present SDFat release and Arduino 1.8.13/Teensyduino 1.53 I did not have this issue?
    Also as I said above the packaged FlexCAN_T4 was also behind the latest release and needed update.
    Bruce
  13. #88
    Mar 2020
    19
    On platformio, after upgrading to framework-arduinoteensy 1.154.0, I can no longer set a HardFault handler.
    Minimal example:
    FASTRUN
    static void hardfault_handler_isr(void) {
        Serial.println("Hardfault");
        Serial.flush();
        while (true);
        while (!Serial);
        _VectorsRam[3] = hardfault_handler_isr;
        Serial.println("Hello!");
        int *p = NULL;
        *p = 3;
        Serial.println(*p);
    With platformio.ini:
    [env:teensy41]
    platform = teensy@4.13.0
    Nothing gets printed.
    [env:teensy41]
    platform = teensy@4.12.0
    I get "Hardfault" on the console.
  14. #89
    15,080
    was an 8 second pause after the caused fault and then a restart seen?
    TD 1.54 added : if ( CrashReport ) Serial.print( CrashReport );
    That comes from info saved in unused_interrupt_vector()
    BUT TD 1.54 has been released - this is an OLD BETA thread at this point ...
  15. #90
    Mar 2020
    19
    Ah yes, I posted in the wrong thread!
    Correct. I get the 8 second pause and restart. How do I get my custom fault handler running again?
  16. #91
    9,285
    There is now "CrashReport" - as defragster mentioned.
    I'll close here. Perhaps ask again in a new thread or "Technical support."
  17. #92
    15,080
    You'd have to look at the unused_interrupt_vector() code in startup.c - and what leads to it.
    To get CrashReport the fault handling was altered for TD 1.54 - not sure but seems that might be behind any change
  18. #93
    Administrator Paul's Avatar
    Oct 2012
    415
    Temporarily reopening this thread, to answer this question
    Quote Originally Posted by damiend View Post
    Minimal example:
    This minimal example generates a memory fault, not a hard fault.
    It works fine with Teensyduino 1.54 if you simple write the function address to _VectorsRam 4 rather than 3.
    FASTRUN
        Serial.flush();
        while (true);
        while (!Serial);
        _VectorsRam[4] = hardfault_handler_isr;
        int *p = NULL;
        *p = 3;
        Serial.println(*p);
  19. #94
    25,052
    Just to further demonstrate, you can generate a hard fault by causing any sort of fault inside the memory fault handler.
    Here's your minimal example extended to cause a memory fault, and then another memory access violation inside the memory fault handler, which then causes a hard fault.
    FASTRUN
        Serial.flush();
        while (true);
    FASTRUN
    static void memoryfault_handler_isr(void) {
        Serial.println("Memoryfault");
        Serial.flush();
        int *p = NULL;
        *p = 3;
        while (true);
        while (!Serial);
        _VectorsRam[4] = memoryfault_handler_isr;
        int *p = NULL;
        *p = 3;
        Serial.println(*p);
    Works as it should with Teensyduino 1.54.
  20. #95
    Oct 2012
    415
    Ok, looks like followup is here:
    https://forum.pjrc.com/threads/67869...ensyduino-1-54
    Closing this thread again.
