Results 1 to 6 of 6
Thread: RawHID recv and send timeout in microseconds
    May 2021
    4
    I use RawHID with a Teensy 4.1 in my project and I need a control loop that run at at least 1kHz. Since RawHID's timeout are measured in ms, it is impossible to have a higher frequency than 500Hz since I call the recv and send function in each loop and they each take at least 1 ms.
    To solve my problem, I went to the source code, in the cores/teensy4/usb_rawhid.c file and change the following :
    int usb_rawhid_recv(void *buffer, uint32_t timeout)
    	uint32_t wait_begin_at = systick_millis_count;
    	uint32_t tail = rx_tail;
    	while (1) {
    		if (!usb_configuration) return -1; // usb not enumerated by host
    		if (tail != rx_head) break;
    		if (systick_millis_count - wait_begin_at > timeout)  {
    			return 0;
    		yield();
    //	digitalWriteFast(0, LOW);
    	if (++tail > RX_NUM) tail = 0;
    	uint32_t i = rx_list[tail];
    	rx_tail = tail;
    	memcpy(buffer,  rx_buffer + i * RAWHID_RX_SIZE, RAWHID_RX_SIZE);
    	rx_queue_transfer(i);
    	//memset(rx_transfer, 0, sizeof(rx_transfer));
    	//usb_prepare_transfer(rx_transfer + 0, rx_buffer, RAWHID_RX_SIZE, 0);
    	//usb_receive(RAWHID_RX_ENDPOINT, rx_transfer + 0);
    	return RAWHID_RX_SIZE;
    int usb_rawhid_send(const void *buffer, uint32_t timeout)
    	transfer_t *xfer = tx_transfer + tx_head;
    	while (1) {
    		uint32_t status = usb_transfer_status(xfer);
    		if (!(status & 0x80)) break; // transfer descriptor ready
    		if (systick_millis_count - wait_begin_at > timeout) return 0;
    		yield();
    	uint8_t *txdata = txbuffer + (tx_head * RAWHID_TX_SIZE);
    	memcpy(txdata, buffer, RAWHID_TX_SIZE);
    	arm_dcache_flush_delete(txdata, RAWHID_TX_SIZE );
    	usb_prepare_transfer(xfer, txdata, RAWHID_TX_SIZE, 0);
    	usb_transmit(RAWHID_TX_ENDPOINT, xfer);
    	if (++tx_head >= TX_NUM) tx_head = 0;
    	return RAWHID_TX_SIZE;
    to :
    	uint32_t wait_begin_at =micros();
    	while (1) {
    		if (micros() - wait_begin_at > timeout)  {
    			return 0;
    		yield();
    	rx_tail = tail;
    	uint32_t wait_begin_at = micros();
    	while (1) {
    		if (micros() - wait_begin_at > timeout) return 0;
    		yield();
    In summary, I changed all systick_millis_count to micros().
    I don't know if those changes can bring other bugs, but so far, this has not caused me any problems. The communication is working and the data I receive is good.
    Request: Implement those changes or something similar in the source code.
    8,576
    Quote Originally Posted by BrunoB81HK View Post
    I hope not. This is incompatible to everything.
    May 2021
    4
    Do you mean incompatible in the sense that older codes which specify the timeout time in milliseconds will need to be changed? If so, there is surely a simple way to make it work regardless. I think that using >= signs instead of > will make it possible to have a timeout of 0 ms.
    If not, I'd like to know why it's incompatible with everything. I wouldn't want my control loop to fail for an unknown reasons.
    9,211
    I believe what Frank B is commenting on, is if you have a sketch that
    calls: usb_rawhid_recv(myBuffer, 100);
    They were expecting the code to wait for up to a 100ms or a tenth of a second to receive a packet, with this change the
    code would only wait for .0001 seconds for a packet. Which could break any app that was expecting to wait the 100ms
    May 2021
    4
    Thanks KurtE for the comprehensive explanation.
    I think the problem is that currently, if I call usb_rawhid_recv(myBuffer, 100); the code wait up to 101 ms, so 1 ms more than asked. This is due to the fact that systick_millis_count is an int and the comparison is done with a > instead of >=.
    I tested the use of >= and it work as expected. Basically, I changed :
    	while (1) {
    			return 0;
    		yield();
    	rx_tail = tail;
    	while (1) {
    		yield();
    to :
    	while (1) {
    		if (systick_millis_count - wait_begin_at >= timeout)  {
    			return 0;
    		yield();
    	rx_tail = tail;
    	while (1) {
    		if (systick_millis_count - wait_begin_at >= timeout) return 0;
    		yield();
    With this change, it is possible to have a timeout of 0 ms.
    Edit :
    When looking at the teensy3 core, I found another way to achieve a 0 ms timeout without changing > to >=. You just change :
    to :
    if (systick_millis_count - wait_begin_at > timeout || !timeout) return 0;
    I didn't test this but it seems like a good way to do it, although it won't fix the fact that the maximum timeout will always be 1 ms more than asked.
    May 2021
    4
    Hi KurtE,
    I was wondering if anyone took a look into this issue. It is pretty annoying to have to manually change the code every time that I need to upload from a new computer.
    I think this change is pretty simple and will not break any existing code.
    Thanks a lot,
    Bruno
