Results 1 to 3 of 3
Thread: Sample manipulation for DIY sampler
    Jun 2021
    6
    Hi
    I'm working on sampler inspired by Volca Sample and it's unofficial firmware
    And I wanted to implement ability to change start and end point of a sample and also reverse and speed up of playback of sample
    How could I achieve it using Audio.h library.
    Also i want to release board code and STLs for people to play around when I'm finished with it.
    I'm currently using Teensy 4.0 and audio board
    Jun 2021
    Italy
    4
    Hi! See my answer on the other thread https://forum.pjrc.com/threads/67555...t-manipulation
    Volca Sample is cool, I'm looking forward to seeing the results of your work!
    Senior Member Rolfdegen's Avatar
    Sep 2020
    227
    I have a Volca drum. The sounds are so cool and it's a lot of fun
    Sample function:
    I built a sample editor into my 8 bit DIY synth "Degenerator". It was'nt easy.
    I can set start and end points and loop points. Delete and OneShoot function is also implemented.
    My Video: https://youtu.be/-QxENbXdaIQ?t=1217
    Greetings Rolf
Tags for this Thread
