I have a teensy 3.2 and a teensy 4.1 plugged into the same laptop. Both teensies are connected to the same ground (the laptop via USB), and there is a jumper cable from the teensy 3.2 DAC/A14 pin to an analog pin on the Teensy 4.1. The teensy 3.2 reads an analog sensor value, clips and compresses that to a [0,1023] range and sends it to the teensy 4.1 via the analog pin to analog pin connection. Unfortunately the signal is quite noisy, and I don't like having to trim and compress the sensor readings to a small range.
I will be adding 4 more teensy 3.2s, each reading one of their own sensors and sending to an analog port on the teensy 4.1.
The reason I didn't do I2C or serial or SIP were because I am under the impression that analog read/write is the fastest, and it seemed the most straightforward. I would like to read and report sensor values at 4kHz.
What is the best way to do this?
