PickyBiker
The attached sketch shows the time on a display, allows it to be updated, and attempts to save any time updates. While everything seems to work okay while it is running, when power is removed the time is restored to the original time settings, not the updated time settings. There is a good battery connected to the teensy 4.
I tried loading the Teensy Arduino IDE software again, but that doesn't help.
What am I doing wrong?
// designed for for teensy 4.0
#include <TimeLib.h>
#include "Adafruit_HX8357.h"
#include <Adafruit_GFX.h> // Core graphics library
#include "TouchScreen.h"
// These are the four touchscreen analog pins
#define YP A2 // must be an analog pin, use "An" notation!
#define XM A3 // must be an analog pin, use "An" notation!
#define YM 7 // can be a digital pin
#define XP 8 // can be a digital pin
TouchScreen tscr = TouchScreen(XP, YP, XM, YM, 500);
#define MINPRESSURE 300
#define MAXPRESSURE 1000
// The display uses hardware SPI, plus #9 & #10
#define TFT_RST 15 // if you dont want to use a reset pin, tie this to arduino RST if you like
#define TFT_DC 9
#define TFT_CS 10
// This is calibration data for the raw touch data to the screen coordinates
#define TS_MINX 110
#define TS_MINY 80
#define TS_MAXX 900
#define TS_MAXY 940
Adafruit_HX8357 tft = Adafruit_HX8357(TFT_CS, TFT_DC, TFT_RST);
// Colors
#define BACKGROUNDCLR 0xA514
#define TEXTCLR 0x0000
#define BUTTONCLR 0xAD75
#define REDCLR 0xA800
struct Button
public:
int x;
int y;
int buttonHeight;
int buttonLength;
void (*funct)(int n);
int arg;
Button myArray[12];
Button item;
boolean AM = true; // true for AM false for PM
int buttonCount = 0; // keeps track of # of buttons on screen
int zIdx = 1, stIdx = 1; // indexes zone = 1-ZONECOUNT, start time = 1-3
void CreateButton(int txSize, int x, int y, String txt, int bgClr, int txClr, void (funct)(int n), int arg)
float charWidth[6] = {6, 6, 12, 18, 24, 28};
float charHeight[6] = {7, 7, 14, 22, 30, 36};
float rectWidth, rectHeight;
rectWidth = (txt.length() + 1) * charWidth[txSize];
rectHeight = charHeight[txSize] + 20;
tft.drawRoundRect(x, y, rectWidth, rectHeight, 10, TEXTCLR);
tft.fillRoundRect(x + 1, y + 1, rectWidth - 2, rectHeight - 2, 10, bgClr);
int txtStartX = x + (charWidth[txSize] / 2) + 1; // Center the TEXTCLR;
int txtStartY = y + 10; // TEXTCLR in the middle
tft.setCursor(txtStartX, txtStartY);
tft.setTextColor(txClr);
tft.setTextSize(txSize);
tft.print(txt);
item.x = x;
item.y = y;
item.buttonLength = rectWidth;
item.buttonHeight = rectHeight;
item.funct = funct;
item.arg = arg;
myArray[buttonCount++] = item;
void setup(void)
pinMode(15, OUTPUT); // TFT Display reset pin
digitalWrite(15, HIGH);
setSyncProvider(getTeensy3Time); // use the Teensy 4.0 RTC timer
StartDisplay(); // start the 3.5" display
if (timeStatus() != timeSet)
Serial.println(F("Unable to sync with RTC"));
Serial.println(F("RTC has set system time"));
if (hour() > 12) // set AM/PM
AM = false;
AM = true;
DrawTimeSetPage(0);
void loop(void)
GetTouch(); // See if a button is touched
CheckTimeDisplay(); // update the time once per minute
time_t getTeensy3Time()
return Teensy3Clock.get();
void CheckTimeDisplay() // display the clock time every minute
static int nMin, oMin;
nMin = minute();
if (oMin != nMin)
DisplayTime();
oMin = nMin;
void Rotation(int n)
tft.setRotation(n);
void StartDisplay()
tft.begin();
delay(200);
Rotation(1);
tft.fillScreen(BACKGROUNDCLR);
tft.setTextColor(TEXTCLR);
tft.setTextSize(3);
void SwitchAMPM(int n)
if (AM == true) AM = false; else AM = true;
DisplayTime();
void WriteText(String txt, int txtSize, int x, int y, int clr)
Rotation(1);
tft.setTextColor(clr);
tft.setTextSize(txtSize);
tft.setCursor(x, y);
tft.print(txt);
void DisplayTime()
int hr = hour(), mn = minute();
String strHr, strMin;
if (hr > 12)
hr = hr - 12;
if (hr < 10)
strHr = "0" + String(hr);
strHr = String(hr);
if (mn < 10)
strMin = "0" + String(mn);
strMin = String(mn);
Rotation(1);
tft.fillRect(284, 5, 90, 21, BACKGROUNDCLR);
WriteText("Current Time " + strHr + ":" + strMin, 3, 50, 5, TEXTCLR);
if (AM)
WriteText("PM", 3, 390, 5, BACKGROUNDCLR);
WriteText("AM", 3, 390, 5, TEXTCLR);
WriteText("AM", 3, 390, 5, BACKGROUNDCLR);
WriteText("PM", 3, 390, 5, TEXTCLR);
void HourUp(int n)
int hr = hour() % 12;
hr += 1;
if (hr > 12)
hr = 1;
setTime(hr, minute(), 0, 1, 1, 2021);
DisplayTime();
void HourDown(int n)
hr -= 1;
if (hr < 1)
hr = 12;
setTime(hr, minute(), 0, 1, 1, 2020);
DisplayTime();
void MinuteUp(int n)
int mn;
mn = minute() + 1;
if (mn > 59)
mn = 0;
setTime(hour(), mn, 0, 1, 1, 2020);
DisplayTime();
void MinuteDown(int n)
int mn;
mn = minute() - 1;
if (mn < 0)
mn = 59;
DisplayTime();
void ClearScreen()
Rotation(1);
tft.fillRoundRect(10, 5, 460, 315, 10, BACKGROUNDCLR);
void Press(int x, int y)
int cnt = buttonCount;
for (int i = 0; i < cnt; i++)
if (x >= myArray[i].x && x <= myArray[i].x + myArray[i].buttonLength)
if (y >= myArray[i].y && y <= myArray[i].y + myArray[i].buttonHeight)
myArray[i].funct(myArray[i].arg); // call the button's function
delay(150);
void GetTouch()
TSPoint p;
Rotation(0);
p.z = 0;
// get a point
p = tscr.getPoint();
if (p.z < MINPRESSURE || p.z > MAXPRESSURE)
return;
// Scale from ~0->1000 to tft.width using the calibration #'s
p.x = map(p.x, TS_MINX, TS_MAXX, tft.width(), 0);
p.y = map(p.y, TS_MINY, TS_MAXY, 0, tft.height());
int s = p.x;
p.x = p.y;
p.y = s;
Press(p.x, p.y);
Rotation(1);
void DrawTimeSetPage(int n)
buttonCount = 0;
ClearScreen();
Rotation(1);
DisplayTime();
WriteText("TIME SET", 2, 190, 40, REDCLR);
CreateButton(2, 150, 80, "Hour", BUTTONCLR, TEXTCLR, HourUp, 0);
CreateButton(2, 230, 80, "Minute", BUTTONCLR, TEXTCLR, MinuteUp, 0);
CreateButton(2, 340, 80, "AMPM", BUTTONCLR, TEXTCLR, SwitchAMPM, 0);
