What is the flightsim library, how or where is it typically used, and can it be used with DCS?
C ChrisCurl Active member May 24, 2021 #1 What is the flightsim library, how or where is it typically used, and can it be used with DCS?
C ChrisCurl Active member May 26, 2021 #2 Doesn't anyone use the Flight Simulator library? Isn't there any documentation on it anywhere?
H Hal New member Apr 24, 2022 #3 See the wiki page at: https://github.com/jbliesener/FlightSimSwitches/wiki
PaulStoffregen Well-known member Apr 24, 2022 #4 It only works with X Plane. You enable it from the Tools > USB Type menu in Arduino. Documentation is here: https://www.pjrc.com/teensy/td_flightsim.html
