teensy_dude
I want to experiment with ethernet using a Teensy 4.1 .
AIUI the standard arduino library will work, is this correct?
I've never done anything ethernet before, but I got the Webserver example working on an arduino with an ethernet shield, so can I just use the same code on the teensy without modification?
Also, for testing for now, can I just wire an ethernet cable to the ethernet RX/TX pins directly, or is the magnetic transformer mandatory?
