Hi all,
I am working on a project which required me to read around 10 sensors as fast as possible. For this purpose I am thinking of using the two ADCs of teensy and using 5 channels of each and sequentially reading each channel. After going through pedivide's ADC library examples and many forum posts on the ADC configuration, I have written an example sketch which reads 1 channel of each ADC simultaneously and calculates the time taken for the reads in contrast to direct analog read.
I was wondering if the approach I have used here is correct for simultaneously using both ADCs. To scale this code for multiple channels I will need to have a complex nested if .. else which determines the pin on which to start the next read. Is there a better approach to accomplish this, I tried looking into interrupts for telling when a conversion was completed but I couldnt understand how I could scale it for multiple channels. All suggestions are welcome as this is my first time working with ADCs.
Thank you!
#include<ADC.h>
#include<ADC_util.h>
const int readPin1 = A9; //ADC0
const int readPin2 = A16; //ADC1
ADC *adc = new ADC();
pinMode(LED_BUILTIN, OUTPUT);
pinMode(readPin1, INPUT);
pinMode(readPin2, INPUT);
adc->adc0->setAveraging(16);
adc->adc0->setResolution(16);
adc->adc0->setConversionSpeed(ADC_CONVERSION_SPEED::HIGH_SPEED_16BITS);
adc->adc0->setSamplingSpeed(ADC_SAMPLING_SPEED::HIGH_SPEED);
adc->adc1->setAveraging(16);
adc->adc1->setResolution(16);
adc->adc1->setConversionSpeed(ADC_CONVERSION_SPEED::HIGH_SPEED_16BITS);
adc->adc1->setSamplingSpeed(ADC_SAMPLING_SPEED::HIGH_SPEED);
adc->adc0->startSingleRead(readPin1);
adc->adc1->startSingleRead(readPin2);
int val1,val2;
uint32_t start = millis();
uint32_t ctr = 0;
// for(int i = 0; i < 10000; i++)
// val1 = adc->adc0->analogRead(readPin1);
// val2 = adc->adc1->analogRead(readPin2);
//Gives around 1268 us for 10 reads
while(ctr < 10000)
if(adc->adc0->isComplete())
val1 = adc->adc0->readSingle();
ctr++;
else if(adc->adc1->isComplete())
val2 = adc->adc1->readSingle();
ctr++;
//Gives around 315 us for 10 reads
uint32_t end = millis();
Serial.print(end - start);
Serial.println(" MicroSeconds for 10 readings");
digitalWriteFast(LED_BUILTIN, !digitalReadFast(LED_BUILTIN));
delay(50);
Thank you!
