Results 1 to 4 of 4
Thread: Missing code written for CS42884 object - Audio Library
    Aug 2016
    Australia
    208
    Hi Paul,
    I was testing some CS42448 functions and found that some of the function overloads for .output() and .input() led to empty servicing code!
    Here is the missing code for control_cs42448.cpp:
    bool AudioControlCS42448::volumeInteger(uint32_t n)
    	uint8_t data[9];
    	data[0] = 0;
    	for (int i=1; i < 9; i++) {
    		data[i] = n;
    	return write(CS42448_DAC_Channel_Mute, data, 9);
    Cross post from https://forum.pjrc.com/threads/67298...ctions-written
    bool AudioControlCS42448::volumeInteger(int channel, uint32_t n)
    	write(CS42448_DAC_Channel_Mute, 0); 			     // unmute all channels
    	return write(CS42448_AOUT1_Volume_Control + channel -1, n); // set this channel
    bool AudioControlCS42448::inputLevelInteger(int32_t n)
    	uint8_t data[6];
    	for (int i = 0; i < 6; i++)
                  data[i] = n;
    	return	write(CS42448_AIN1_Volume_Control, data, 6); // set all channels (not 7 & 8)
    bool AudioControlCS42448::inputLevelInteger(int channel, int32_t n)
    	return write(CS42448_AIN1_Volume_Control + channel -1, n); // set this channel
    Also, in control_cs42448.h, I believe the correct return value for the return value for a gain of -127.5dB is 255, rather than 128. (CS4428 data sheet P 50.)
    	// convert level to volume byte, section 6.9.1, page 50
    	uint32_t volumebyte(float level) {
    		if (level >= 1.0) return 0;
    		if (level <= 0.0000003981) return 255;
    		return roundf(log10f(level) * -20.0);
    This is a cross post from 67298-Missing-CS42448-control-functions-written
    Richard
    Sep 2019
    Sevilla, Spain
    66
    Hi @palmerr,
    in the post you have a difference in the code:
    return roundf(log10f(level) * -40.0);
    Quote Originally Posted by palmerr View Post
    Richard
    is it the last the right one?
    Aug 2016
    Australia
    208
    Thanks for catching it. The other post is correct.
    The steps are 0.5dB therefore the multiplier should be -40.
    I hope you have fun with the code. I've found it very useful to be able to use positive gains on the input PGAs. They do get a bit noisy towards maximum gain, so not recommended for microphone preamps, but quite usable to boost domestic-level (100mV) audio signals. With gain < 1 they have little real use, as they have the same input level restrictions as the ADCs.
    I've found the output level less useful, as it doesn't do anything that a mixer Audio object can't do.
    My guess is that these practical restrictions are why Paul didn't complete the code in the first place.
    Nov 2019
    Piedmont, OK
    12
    Those are very helpful - thanks for posting!
    I use the following to read the status register from the CS42448. Maybe you'll find them useful
    bool AudioControlCS42448::read(uint32_t address)
    	// reads registers values
    	uint8_t c = 0;
    	// pg38, control port read operation
    	//Send a start condition
    	Wire.beginTransmission(i2c_addr);
    	// send chip address and write operation
    	Wire.write(address);
    	Wire.endTransmission(true);
    	//rx ack bit, send MAP byte
    	Wire.requestFrom( (int) i2c_addr, 1);
    	while(Wire.available()) {
    		Serial.print("Register ");
    		Serial.print(address, HEX);
    		Serial.print(" = ");
    		c = Wire.read();
    		Serial.println(c, BIN);
    	return true;
    uint8_t AudioControlCS42448::get(uint32_t address)
    	uint8_t c = 0;
    		c = Wire.read();
    		//Serial.println(c, BIN);
    	return c;
