Adafruit ISM330DHCX not working in SPI mode on Teensy 4.1
MatArnold
Having trouble with SPI connections to my Teensy 4.1. Specifically an IMU breakout from Adafruit, the ISM330DHCX. I did look at the other thread on an Adafruit IMU in SPI mode but I could not find a solution to my problem. My code is below, simply the provided Adafruit testing example.
#include <Arduino.h>
#include <Adafruit_ISM330DHCX.h>
#include <Adafruit_Sensor.h>
// For SPI mode, we need a CS pin
#define LSM_CS 10
// For software-SPI mode we need SCK/MOSI/MISO pins
#define LSM_SCK 13
#define LSM_MISO 12
#define LSM_MOSI 11
Adafruit_ISM330DHCX ism330dhcx;
void setup(void) {
  pinMode(10,OUTPUT); // set default spi CS to high
  while (!Serial)
    delay(10); // will pause Zero, Leonardo, etc until serial console opens
  Serial.println("Adafruit ISM330DHCX test!");
  // if (!ism330dhcx.begin_I2C()) {
    if (!ism330dhcx.begin_SPI(LSM_CS)) {
    // if (!ism330dhcx.begin_SPI(LSM_CS, LSM_SCK, LSM_MISO, LSM_MOSI)) {
    Serial.println("Failed to find ISM330DHCX chip");
    while (1) {
      delay(10);
  Serial.println("ISM330DHCX Found!");
  //ism330dhcx.setAccelRange(LSM6DS_ACCEL_RANGE_4_G);
  Serial.print("Accelerometer range set to: ");
  switch (ism330dhcx.getAccelRange()) {
  case LSM6DS_ACCEL_RANGE_2_G:
    Serial.println("+-2G");
  case LSM6DS_ACCEL_RANGE_4_G:
    Serial.println("+-4G");
  case LSM6DS_ACCEL_RANGE_8_G:
    Serial.println("+-8G");
  case LSM6DS_ACCEL_RANGE_16_G:
    Serial.println("+-16G");
  ism330dhcx.setGyroRange(LSM6DS_GYRO_RANGE_250_DPS);
  Serial.print("Gyro range set to: ");
  switch (ism330dhcx.getGyroRange()) {
  case LSM6DS_GYRO_RANGE_125_DPS:
    Serial.println("125 degrees/s");
  case LSM6DS_GYRO_RANGE_250_DPS:
    Serial.println("250 degrees/s");
  case LSM6DS_GYRO_RANGE_500_DPS:
    Serial.println("500 degrees/s");
  case LSM6DS_GYRO_RANGE_1000_DPS:
    Serial.println("1000 degrees/s");
  case LSM6DS_GYRO_RANGE_2000_DPS:
    Serial.println("2000 degrees/s");
  case ISM330DHCX_GYRO_RANGE_4000_DPS:
    Serial.println("4000 degrees/s");
  // ism330dhcx.setAccelDataRate(LSM6DS_RATE_12_5_HZ);
  Serial.print("Accelerometer data rate set to: ");
  switch (ism330dhcx.getAccelDataRate()) {
  case LSM6DS_RATE_SHUTDOWN:
    Serial.println("0 Hz");
  case LSM6DS_RATE_12_5_HZ:
    Serial.println("12.5 Hz");
  case LSM6DS_RATE_26_HZ:
    Serial.println("26 Hz");
  case LSM6DS_RATE_52_HZ:
    Serial.println("52 Hz");
  case LSM6DS_RATE_104_HZ:
    Serial.println("104 Hz");
  case LSM6DS_RATE_208_HZ:
    Serial.println("208 Hz");
  case LSM6DS_RATE_416_HZ:
    Serial.println("416 Hz");
  case LSM6DS_RATE_833_HZ:
    Serial.println("833 Hz");
  case LSM6DS_RATE_1_66K_HZ:
    Serial.println("1.66 KHz");
  case LSM6DS_RATE_3_33K_HZ:
    Serial.println("3.33 KHz");
  case LSM6DS_RATE_6_66K_HZ:
    Serial.println("6.66 KHz");
  // ism330dhcx.setGyroDataRate(LSM6DS_RATE_12_5_HZ);
  Serial.print("Gyro data rate set to: ");
  switch (ism330dhcx.getGyroDataRate()) {
  ism330dhcx.configInt1(false, false, true); // accelerometer DRDY on INT1
  ism330dhcx.configInt2(false, true, false); // gyro DRDY on INT2
  // IMU
  //  /* Get a new normalized sensor event */
  sensors_event_t accel;
  sensors_event_t gyro;
  sensors_event_t temp;
  ism330dhcx.getEvent(&accel, &gyro, &temp);
  Serial.print("\t\tTemperature ");
  Serial.print(temp.temperature);
  Serial.println(" deg C");
  /* Display the results (acceleration is measured in m/s^2) */
  Serial.print("\t\tAccel X: ");
  Serial.print(accel.acceleration.x);
  Serial.print(" \tY: ");
  Serial.print(accel.acceleration.y);
  Serial.print(" \tZ: ");
  Serial.print(accel.acceleration.z);
  Serial.println(" m/s^2 ");
  /* Display the results (rotation is measured in rad/s) */
  Serial.print("\t\tGyro X: ");
  Serial.print(gyro.gyro.x);
  Serial.print(gyro.gyro.y);
  Serial.print(gyro.gyro.z);
  Serial.println(" radians/s ");
  //  // serial plotter friendly format
  //  Serial.print(temp.temperature);
  //  Serial.print(",");
  //  Serial.print(accel.acceleration.x);
  //  Serial.print(","); Serial.print(accel.acceleration.y);
  //  Serial.print(","); Serial.print(accel.acceleration.z);
  // Serial.print(gyro.gyro.x);
  // Serial.print(","); Serial.print(gyro.gyro.y);
  // Serial.print(","); Serial.print(gyro.gyro.z);
  // Serial.println();
  //  delayMicroseconds(10000);
I have a barometer from Adafruit running in SPI mode with no issues, and I've run the ISM330DHCX in SPI mode off of my Arduino MEGA 2560 without issue. What's strange is ism330dhcx.begin_SPI(LSM_CS) returns true, however the accelerometer options can't be changed and the output is a set of values that do not update as the ISM330DHCX is moved, and they do work in I2C mode or in SPI mode running from the MEGA. I think the wiring is correct, the Barometer runs fine off of the same SPI pins, just with CS set to 9.
The outputs look like:
ISM330DHCX Found!
Accelerometer range set to: +-2G
Gyro range set to: Accelerometer data rate set to: 1.66 KHz
Gyro data rate set to: 1.66 KHz
Temperature 25.50 deg C
Accel X: 0.00 Y: 0.00 Z: -9.79 m/s^2
Gyro X: 0.00 Y: 0.00 Z: 0.00 radians/s
I'm probably overlooking something, hopefully someone is able to offer some guidance. Thank you!
Update, tried with another Teensy 4.1 I had, same exact result. If someone is able to point me in a direction to investigate, that would be extraordinarily helpful.
Here is a picture of the wiring:
Sorry, I am not seeing that Adafruit library anywhere... At least the library manager does not show it nor does quick look on github. Is this part of a different Adafruit library?
Could be something like a timing issue, where you may need to put well placed delays in, as the teensy 4.1 will run things a lot faster than an 16mhz AVR board
Sorry I have not had a chance to look at their source code or look at the devices manual to know what the timing requirements are.
Some of the things I would look at include:
Does the code use SPI transactions? that is SPI.beginTransaction(....) If not maybe try to convert.
Other things like: if the code does:
digitalWrite(CS_PIN, LOW);
SPI.transfer(...)
Maybe the device need a small delay between setting the CS and doing transfer.
I completely replaced Platform IOs version of teensyduino with the latest release, and it worked! I completely replaced the teensy>avr>cores and the teensy>avr>libraries contents and got everything working. Thank you so much!
