Hello all, I’m new to the world of Teensy after having spent a lot of time working on Arduino’s. A friend of mine sent me a board that uses Teensy 4.1 to coordinate the combination action on a digital organ. In order to protect the computer’s USB connection, however, I was instructed to cut the small trace between the Vin and Vusb pads. I cut it, but I think I cut too deep and damaged another internal trace, because the teensy refused to boot up after that, even when supplying the Vin with appropriate 5v power. However, when I applied a small blob of solder to the pads, Teensy booted up normally, and I was able to upload a program. In the meanwhile, I am planning on cutting the red wire from a USB cable so I can at least get it working, however I would like to solder a jumper so that I can use normal USB cables in the future. Would anybody be able to tell me where I should solder the jumper from and to? I know where to solder a jumper on a teensy 3.2, but the board layout is quite different on the 4.1. Thanks!
