Results 1 to 5 of 5
Thread: Teensy 4.1 - Using CTX1 and MOSI
    Jun 2017
    127
    Hello:
    I have a Teensy 4.1 which is interfaced to a CAN controller via CRX1 and CTX1 (pins 23, 22).
    I need to use the Teensy41 with this SPI LCD (http://simple-circuit.com/arduino-st...splay-example/).
    I just noticed that pin 11(MOSI) is also CTX1. I cannot use CRX2, CTX2 because I am using it as a serial port.
    Will this cause problems and is there a way around this?
    Thanks in advance for the community's help.
    Dec 2016
    Montreal, Canada
    3,797
    you can continue using pins 23,22 for CAN. By default the state of pin 11 is INPUT_DISABLE (high impedance state). The moment you use SPI.begin() it is assigned as MOSI, and NOT CAN. The pins have many functions, but programatically, they can only be one or the other.
    Jun 2017
    127
    Thank you @tonton81.
    If I understand you, this means that once the LCD which uses SPI starts, CAN1 stops working?
    Dec 2016
    Montreal, Canada
    3,797
    no CAN continues working on pins 23,22
    pin11 is just an alternate pin for CAN, it is not configured to be CAN only SPI
    Jun 2017
    127
    Thank you @tonton81. This is great news.
