Results 1 to 5 of 5
Thread: OpenDrain with high voltage
    Jun 2021
    2
    Hi everyone,
    I did not find my answer on the forum or I did not understand exactly the others posts that are talking about this, so here I am.
    I have a teensy 3.5 and need to control a 10V output with PWM. I tried using a PNP transistor but what I did does not work, I already have bought the PCB so I can just make a few corrections (yes maybe next time I will think a bit more about what I do).
    Here is the schematics that I have:
Name:	PNP alone.PNG
    Currently the output is always to 10V, I think the 3.3V of the teensy are not enough to make the transistor commutate.
    My idea would be to add a pull-up resistor to the input of the transistor and to control the pin with the open drain mode. As I understood, the open drain mode allows to use a different voltage than 3.3V, as long as this voltage is supported. Do you think that the teensy will support 10V on one GPIO with the OUTPUT_OPENDRAIN mode? If not, do you have any idea that could save me? ^^'
    Here is the schematics that I would have:
Name:	PNP with Pull-up.PNG
    Thanks!
    Alexandre
    24,482
    Quote Originally Posted by Alexandre T View Post
    No, definitely not. The pin is 5V tolerant. It's not 10V tolerant!
    Jun 2021
    2
    Okay, good thing I asked before trying then.
    Thank you!
    May 2015
    USA
    1,003
    I'm curious - is there some amount of series resistance where a teensy 3.5 output does become 10V tolerant?
    You could add a diode to limit the voltage seen by the teensy pin.
    Jul 2020
    1,112
    I wouldn't have expected a PNP to be useful for level conversion to a higher voltage - NPN common-emitter inverter
    circuit is what's used - in other words low-side switching. Since BJTs turn on at around 0.65V, 3.3V is plenty, just
    set the base resistor so that the base current will be about 5 to 10% of the desired collector current.
