Badbidaman
Hello! I'm loving the Teensy, I have the 4.1 with an audio shield. I've written a code for a drum machine with 2 piezo pickups (rightPiezo for bass sounds, leftPiezo for snare sounds). Basically I want to hit the piezo pickups and have WAV files play along with some LED lights going off. I am not sure why my code doesn't work (it complies and the lights blink, but no sounds)... if anyone has any insight for me that would be awesome. Thanks in advance!
Here is the code:
Here is the code:
#include <SerialFlash.h>
/*This initial setup is important because I have added 2 mixers.
This means that playSdWav1 and playSdWav2 can be played at the same time*/
AudioPlaySdWav playSdWav1;
AudioPlaySdWav playSdWav2;
AudioMixer4 mixer1;
AudioMixer4 mixer2;
AudioOutputI2S audioOutput;
AudioConnection patchCord1(playSdWav1, 0, mixer1, 0);
AudioConnection patchCord2(playSdWav1, 1, mixer2, 0);
AudioConnection patchCord3(playSdWav2, 0, mixer1, 1);
AudioConnection patchCord4(playSdWav2, 1, mixer2, 1);
AudioConnection patchCord5(mixer1, 0, audioOutput, 0);
AudioConnection patchCord6(mixer2, 0, audioOutput, 1);
#define SDCARD_CS_PIN BUILTIN_SDCARD
#define SDCARD_MOSI_PIN 7
#define SDCARD_SCK_PIN 14
// lights
const int yellow = 2; // led connected to pin 2.
const int white = 3; // led connected to pin 3.
const int green = 4; // led connected to pin 4.
const int blue = 5; // led connected to pin 5.
const int killSwitch = 6;
const int rightPiezo = A0; // right piezo on analog pin 1
const int leftPiezo = A1; // left piezo on analog pin 2
int rightsensorReading = 0;
int leftsensorReading = 0;
int ledState = LOW;
const int threshold = 5; /*do we need this if we're using the Peak capture method? */
bool shouldRunPattern1 = true;
bool shouldRunPattern2 = true;
bool shouldPlaySound1 = false;
bool shouldPlaySound2 = false;
long pattern1Start = 0;
long pattern2Start = 0;
AudioMemory(20);
sgtl5000_1.enable();
sgtl5000_1.volume(0.5);
AudioNoInterrupts();
pinMode(yellow, OUTPUT);
pinMode(white, OUTPUT);
pinMode(green, OUTPUT);
pinMode(blue, OUTPUT);
/*if (digitalRead(killSwitch) == LOW) {
return; } */
if (shouldPlaySound1) {
playSdWav1.play("RKIT.WAV");
if (shouldPlaySound2) {
playSdWav2.play("LKIT.WAV");
// read sensors and set variables
rightsensorReading = analogRead(rightPiezo);
leftsensorReading = analogRead(leftPiezo);
/* volume control, #s are somewhat subjective,
will need adjusting once pedal is built*/
float volume = 0.0;
if (rightPiezo < 5) {
volume = 0.0;
} else if (rightPiezo <= 10) {
volume = 0.4;
} else if (rightPiezo <= 22) {
volume = 0.7;
volume = 1.0;
if (leftPiezo < 5) {
volume = 0.0;
} else if (leftPiezo <= 10) {
volume = 0.4;
} else if (leftPiezo <= 22) {
volume = 0.7;
volume = 1.0;
// initialize the pattern1
if (rightsensorReading >= threshold) {
shouldPlaySound1 = true;
pattern1Start = millis();
// initialize the pattern2
if (leftsensorReading >= threshold) {
shouldPlaySound2 = true;
pattern2Start = millis();
// how long it's been since pattern1 was started
long pattern1Duration = millis() - pattern1Start;
// how long it's been since pattern2 was started
long pattern2Duration = millis() - pattern2Start;
// change this to change how long the LEDs stay on
long patternPulseTime = 200; // .2 seconds
// run pattern 1
if (shouldRunPattern1) {
// green and blue on
if (pattern1Duration < patternPulseTime) {
digitalWrite(green, HIGH);
digitalWrite(blue, HIGH);
// green and blue off for second half second
else {
digitalWrite(green, LOW);
digitalWrite(blue, LOW);
shouldRunPattern1 = false;
// run pattern 2 (same as pattern1 just different leds)
if (shouldRunPattern2) {
if (pattern2Duration < patternPulseTime) {
digitalWrite(yellow, HIGH);
digitalWrite(white, HIGH);
digitalWrite(yellow, LOW);
digitalWrite(white, LOW);
shouldRunPattern2 = false;
