Results 1 to 8 of 8
Thread: Selecting microphone input produces static/noise/etc.
    Jun 2021
    4
    I soldered up an electret condenser mic that I had laying around to the mic and gnd pins. Red to mic, black to gnd.
    However, I don't hear any audio when doing a passthrough test with my headphones. As i raise the mic gain, i hear more and more noise. Touching my fingers on the pin, I am able to generate some noise as well, but absolutely no audio. I've even tried smacking the small mic on the table -- not even a pop.
    Any idea what the problem could be?
    Here is a link to the mic I am using:
    https://www.digikey.com/en/products/...-L120/10253440
    Hardware:
    Audio Board Rev D
    Teensy 4.1
    Here is the code I am using:
    AudioInputI2S            i2s2;           //xy=222,170
    AudioOutputI2S           i2s1;           //xy=578,170
    AudioConnection          patchCord1(i2s2, 0, i2s1, 0);
    AudioControlSGTL5000     sgtl5000_1;     //xy=156,296
    const int myInput = AUDIO_INPUT_MIC;
      AudioMemory(8);
      sgtl5000_1.enable();
      sgtl5000_1.volume(0.8);
      sgtl5000_1.micGain(63);
    1,687
    A condenser mic needs power. The circuit diagram at the bottom of page 3 of the datasheet shows how to wire the power and a capacitor to the red lead. The specifications on page 1 give the typical supply voltage as 2V and a maximum of 10V. The Teensy 3V3 is well within this so you should have no trouble with it.
    Pete
    Jun 2021
    4
    Pete
    According to the Audio adapter board schematic, bias voltage is already provided for condenser mics:
Name:	Screen Shot 2021-06-07 at 6.43.46 PM.png
    Is this not actually on the board?
    1,687
    You are correct. Sorry.
    Your code should give you some audio.
    Pete
    24,453
    From everything you've described, it really should work.
    As you can see in the audio library tutorial (and video demo) this does work.
    Quote Originally Posted by rainnw View Post
    Kinda feels like a defective mic or wire between the mic and Teensy.
    Jun 2021
    4
    Thanks Paul and el_supermo for helping me troubleshoot this. I will order another mic off arrow and see if that helps.
    Jun 2021
    4
    UPDATE: The new microphone i ordered (a slight variant) still provides the same old static: https://www.arrow.com/en/products/cm...82/cui-devices
    I have verified my headphones are working, as the tone examples work great.
    Is the hardware indeed bad?
    Jul 2020
    1,101
    If you connect a capacitor between mic and gnd inputs, do you still get static?
