Results 1 to 8 of 8
Thread: play with image rotations in degrees ILI9341_t3n
    May 2021
    13
    sorry for english translation online
    I'm currently having fun playing with ILI9341_t3n on a 240 x 320px screen, I shift an image of width X and height Y from left to right and from top to bottom see diagonally.
    I would like to make rotations with the axis of rotation positioned on the screen so random on the image.
    I understood that it was necessary to make a matice, to define the point of arrival and to go to seek the corresponding point in the starting image to avoid the holes.
    do you think this can be interesting?
    Nov 2015
    Cold hollow VT
    204
    That would be a really challenging project. Lots of matrix math with SIN() & COS() to move the image points around.
    May 2021
    13
    hello grease_lighting, yes it can do a lot of calculation ... probably for this reason nobody does it but I told myself to see the speed of this library and the asynchronous mode ... why not.
    Actually I have an image of 720X866 pixels which moves without any problem, see even too fast
    Jul 2020
    1,235
    Arbitrary image rotation can be done without any trig, you decompose the rotation into 3 othogonal shear transforms
    and implement these shears directly on the pixel data, snapping to the nearest grid point.
    https://www.ocf.berkeley.edu/~fricke..._shearing.html
    This sort of pixel manipulation is in principle lossless when undone (the complexity is what to do about clipping/cropping)
    May 2021
    13
    Hello MarkT ,
    thank you for this information, I did not know, I will watch it with passion this weekend, moreover, with this method, we must be able to keep a certain fluidity.
    May 2021
    13
    Hello, here is my little help function of the web but I have two problems.
    1 / I have the impression that it does not turn degree by degree.
    2 / how should I proceed to read the image I have in the program?
    void rotation_image(){
        int largeur = 720 / 2; //taille de limage et centre
        int hauteur = 866 / 2; //taille de limage et centre
        int x =0;
        int y =0;
        int x2 = 0;
        int y2 = 0;
        double anglevariable=0;
        double sin2 = 0;
        double cos2 = 0;
      for(int i=0; i<360;i++){//faire une rotation de 360 degres
      display.fillScreen(BLACK);
      //Serial.println(i);
    anglevariable=i;
    sin2 = sin(-anglevariable);
    cos2 = cos(-anglevariable);
    for(int x = 0; x < 720; x++) {
      for(int y = 0; y < 866; y++) {
       x2 = x - largeur;
       y2 = y - hauteur;
        int nouveaux = (int)round((cos2 * x2 - sin2 * y2) + largeur);
        int nouveauy = (int)round((sin2 * x2 + cos2 * y2) + hauteur);
        if(nouveaux >= 0 && nouveaux < 720 && nouveauy >= 0 && nouveauy < 866) {
          display.drawPixel(nouveaux,nouveauy,RED);
          //display.writeRect(0, 0, 720, 866, (uint16_t*)ecran2); ???????
          display.drawPixel(nouveaux,nouveauy,ORANGE);
      }delay(1000);
    or how to implement the function which is in pascal?
    May 2020
    UK
    3
    Lightbulb
    It doesn't rotate by degrees because the trig functions you are calling take their input in radians. Try anglevariable = i * PI / 180.;
    As for reading a texture, perhaps it's easier to point you at some code which does that. Every 2 seconds that swaps between nearest-neighbour and bilinear sampling. I did everything using fixed-point maths because that code targets AVR, but on Teensy 4 I would probably use floats.
    By multiplying the rotation matrix by a scaling factor, you get what is often called a rotzoomer. Searching that term may lead to articles that help with your understanding.
    And, yes, I find this kind of thing very interesting.
    May 2021
    13
    Hi sutaburosu,
    thank you for your help
    yes indeed, it works better in degrees rather when radian, that's already a good thing
    Mais je suis encore loin du resultat rechercher, il y a encore du boulot mais peut de temps de libre en ce moment.
