Hi everyone,
I'm just getting started with using an Ethernet module and a Teensy 3.5 together. My end goal is to upload a .csv file stored on the SD card to a google drive.. but I'm nowhere near yet!
I've got the WIZ820io module wired up to my Teensy 3.5 and I'm certain that's wired correctly, I have the Ethernet cable running from the port on my laptop to the module.
Whenever I run any of the Ethernet examples I always get 'Ethernet shield was not found'.
How do I find the correct IP address of the module? Is it the same as my laptop?
I know the MAC address can effectively be anything, so I've just left that as in the example. I've also tried adding in the code to pulse the reset pin on the module, still nothing changes.
Can anyone help please?
Thank you!
Thank you!
