Results 1 to 16 of 16
Thread: Teensy 4.0 cant see a I2C device in port 1
    Jun 2021
    6
    Hi everyone!
    I'm trying to solve this, but I cant find any information who helps me untill now, so I decide to ask the community. This is the problem:
    I'm trying to use an lcd 1602 through I2C port 1, when I did in port 0 everything goes perfect, but I cant do it in port 1. I used the "scanner" example of the Wire library, and it shows "No I2C devices found". I also tried with other I2C libraries, but nothing happened... Any idea? TRhanks!
    The example code:
      // uncomment these to use alternate pins
      Wire.setSCL(16);
      Wire.setSDA(17);
      Wire.begin();
      while (!Serial);        // Leonardo: wait for serial monitor
      Serial.println(F("\nI2C Scanner"));
      byte error, address;
      int nDevices;
      Serial.println(F("Scanning..."));
      nDevices = 0;
      for (address = 1; address < 127; address++) {
        // The i2c_scanner uses the return value of
        // the Write.endTransmisstion to see if
        // a device did acknowledge to the address.
        Wire.beginTransmission(address);
        error = Wire.endTransmission();
        if (error == 0) {
          Serial.print(F("Device found at address 0x"));
          if (address < 16) {
            Serial.print("0");
          Serial.print(address,HEX);
          Serial.print("  (");
          printKnownChips(address);
          Serial.println(")");
          nDevices++;
        } else if (error==4) {
          Serial.print(F("Unknown error at address 0x"));
          if (address < 16) {
            Serial.print("0");
          Serial.println(address,HEX);
      if (nDevices == 0) {
        Serial.println(F("No I2C devices found\n"));
        Serial.println(F("done\n"));
      delay(5000);           // wait 5 seconds for next scan
    void printKnownChips(byte address)
      // Is this list missing part numbers for chips you use?
      // Please suggest additions here:
      // https://github.com/PaulStoffregen/Wire/issues/new
      switch (address) {
        case 0x00: Serial.print(F("AS3935")); break;
        case 0x01: Serial.print(F("AS3935")); break;
        case 0x02: Serial.print(F("AS3935")); break;
        case 0x03: Serial.print(F("AS3935")); break;
        case 0x0A: Serial.print(F("SGTL5000")); break; // MCLK required
        case 0x0B: Serial.print(F("SMBusBattery?")); break;
        case 0x0C: Serial.print(F("AK8963")); break;
        case 0x10: Serial.print(F("CS4272")); break;
        case 0x11: Serial.print(F("Si4713")); break;
        case 0x13: Serial.print(F("VCNL4000,AK4558")); break;
        case 0x18: Serial.print(F("LIS331DLH")); break;
        case 0x19: Serial.print(F("LSM303,LIS331DLH")); break;
        case 0x1A: Serial.print(F("WM8731")); break;
        case 0x1C: Serial.print(F("LIS3MDL")); break;
        case 0x1D: Serial.print(F("LSM303D,LSM9DS0,ADXL345,MMA7455L,LSM9DS1,LIS3DSH")); break;
        case 0x1E: Serial.print(F("LSM303D,HMC5883L,FXOS8700,LIS3DSH")); break;
        case 0x20: Serial.print(F("MCP23017,MCP23008,PCF8574,FXAS21002,SoilMoisture")); break;
        case 0x21: Serial.print(F("MCP23017,MCP23008,PCF8574")); break;
        case 0x22: Serial.print(F("MCP23017,MCP23008,PCF8574")); break;
        case 0x23: Serial.print(F("MCP23017,MCP23008,PCF8574")); break;
        case 0x24: Serial.print(F("MCP23017,MCP23008,PCF8574")); break;
        case 0x25: Serial.print(F("MCP23017,MCP23008,PCF8574")); break;
        case 0x26: Serial.print(F("MCP23017,MCP23008,PCF8574")); break;
        case 0x27: Serial.print(F("MCP23017,MCP23008,PCF8574,LCD16x2,DigoleDisplay")); break;
        case 0x28: Serial.print(F("BNO055,EM7180,CAP1188")); break;
        case 0x29: Serial.print(F("TSL2561,VL6180,TSL2561,TSL2591,BNO055,CAP1188")); break;
        case 0x2A: Serial.print(F("SGTL5000,CAP1188")); break;
        case 0x2B: Serial.print(F("CAP1188")); break;
        case 0x2C: Serial.print(F("MCP44XX ePot")); break;
        case 0x2D: Serial.print(F("MCP44XX ePot")); break;
        case 0x2E: Serial.print(F("MCP44XX ePot")); break;
        case 0x2F: Serial.print(F("MCP44XX ePot")); break;
        case 0x30: Serial.print(F("Si7210")); break;
        case 0x31: Serial.print(F("Si7210")); break;
        case 0x32: Serial.print(F("Si7210")); break;
        case 0x33: Serial.print(F("MAX11614,MAX11615,Si7210")); break;
        case 0x34: Serial.print(F("MAX11612,MAX11613")); break;
        case 0x35: Serial.print(F("MAX11616,MAX11617")); break;
        case 0x38: Serial.print(F("RA8875,FT6206,MAX98390")); break;
        case 0x39: Serial.print(F("TSL2561, APDS9960")); break;
        case 0x3C: Serial.print(F("SSD1306,DigisparkOLED")); break;
        case 0x3D: Serial.print(F("SSD1306")); break;
        case 0x40: Serial.print(F("PCA9685,Si7021,MS8607")); break;
        case 0x41: Serial.print(F("STMPE610,PCA9685")); break;
        case 0x42: Serial.print(F("PCA9685")); break;
        case 0x43: Serial.print(F("PCA9685")); break;
        case 0x44: Serial.print(F("PCA9685, SHT3X")); break;
        case 0x45: Serial.print(F("PCA9685, SHT3X")); break;
        case 0x46: Serial.print(F("PCA9685")); break;
        case 0x47: Serial.print(F("PCA9685")); break;
        case 0x48: Serial.print(F("ADS1115,PN532,TMP102,LM75,PCF8591")); break;
        case 0x49: Serial.print(F("ADS1115,TSL2561,PCF8591")); break;
        case 0x4A: Serial.print(F("ADS1115,Qwiic Keypad")); break;
        case 0x4B: Serial.print(F("ADS1115,TMP102,BNO080,Qwiic Keypad")); break;
        case 0x50: Serial.print(F("EEPROM,FRAM")); break;
        case 0x51: Serial.print(F("EEPROM")); break;
        case 0x52: Serial.print(F("Nunchuk,EEPROM")); break;
        case 0x53: Serial.print(F("ADXL345,EEPROM")); break;
        case 0x54: Serial.print(F("EEPROM")); break;
        case 0x55: Serial.print(F("EEPROM")); break;
        case 0x56: Serial.print(F("EEPROM")); break;
        case 0x57: Serial.print(F("EEPROM")); break;
        case 0x58: Serial.print(F("TPA2016,MAX21100")); break;
        case 0x5A: Serial.print(F("MPR121")); break;
        case 0x60: Serial.print(F("MPL3115,MCP4725,MCP4728,TEA5767,Si5351")); break;
        case 0x61: Serial.print(F("MCP4725,AtlasEzoDO")); break;
        case 0x62: Serial.print(F("LidarLite,MCP4725,AtlasEzoORP")); break;
        case 0x63: Serial.print(F("MCP4725,AtlasEzoPH")); break;
        case 0x64: Serial.print(F("AtlasEzoEC")); break;
        case 0x66: Serial.print(F("AtlasEzoRTD")); break;
        case 0x68: Serial.print(F("DS1307,DS3231,MPU6050,MPU9050,MPU9250,ITG3200,ITG3701,LSM9DS0,L3G4200D")); break;
        case 0x69: Serial.print(F("MPU6050,MPU9050,MPU9250,ITG3701,L3G4200D")); break;
        case 0x6A: Serial.print(F("LSM9DS1")); break;
        case 0x6B: Serial.print(F("LSM9DS0")); break;
        case 0x6F: Serial.print(F("Qwiic Button")); break;
        case 0x70: Serial.print(F("HT16K33")); break;
        case 0x71: Serial.print(F("SFE7SEG,HT16K33")); break;
        case 0x72: Serial.print(F("HT16K33")); break;
        case 0x73: Serial.print(F("HT16K33")); break;
        case 0x76: Serial.print(F("MS5607,MS5611,MS5637,BMP280")); break;
        case 0x77: Serial.print(F("BMP085,BMA180,BMP280,MS5611")); break;
        case 0x7C: Serial.print(F("FRAM_ID")); break;
        default: Serial.print(F("unknown chip"));
    Cheltenham, UK
    298
    If the scanner did not find it then perhaps it is wired up incorrectly or to the wrong pins
    Jun 2021
    6
    Thanks for your answer, actually I checked the connection many times and that is ok... I think is a problem of the port 1, because there is no problem if I use the port 0
    Cheltenham, UK
    298
    Sorry the default scanner only scans Wire not Wire1 or Wire2.
    Below is a scanner which will scan 3 Wire channels.
    Its not mine but modified by someone on this forum. I can't remember who.
    // i2c_scanner
    // http://playground.arduino.cc/Main/I2cScanner
    // Version 1
    //    This program (or code that looks like it)
    //    can be found in many places.
    //    For example on the Arduino.cc forum.
    //    The original author is not know.
    // Version 2, Juni 2012, Using Arduino 1.0.1
    //     Adapted to be as simple as possible by Arduino.cc user Krodal
    // Version 3, Feb 26  2013
    //    V3 by louarnold
    // Version 4, March 3, 2013, Using Arduino 1.0.3
    //    by Arduino.cc user Krodal.
    //    Changes by louarnold removed.
    //    Scanning addresses changed from 0...127 to 1...119,
    //    according to the i2c scanner by Nick Gammon
    //    http://www.gammon.com.au/forum/?id=10896
    // Version 5, March 28, 2013
    //    As version 4, but address scans now to 127.
    //    A sensor seems to use address 120.
    // Version 6, November 27, 2015.
    //    Added waiting for the Leonardo serial communication.
    // This sketch tests the standard 7-bit addresses
    // Devices with higher bit address might not be seen properly.
    // BUGBUG::Should put this in WireIMXRT.h
    #if defined(__IMXRT1062__)
    #define WIRE_IMPLEMENT_WIRE
    #define WIRE_IMPLEMENT_WIRE1
    #define WIRE_IMPLEMENT_WIRE2
    typedef struct {
      TwoWire *_wire;
      const char * wire_name;
      IMXRT_LPI2C_t * const port;
    } wire_list_t;
    wire_list_t wireList[] = {
      {&Wire, "Wire", &IMXRT_LPI2C1}
    #if defined(WIRE_IMPLEMENT_WIRE1)
      , {&Wire1, "Wire1", &IMXRT_LPI2C3}
    #if defined(WIRE_IMPLEMENT_WIRE2)
      , {&Wire2, "Wire2", &IMXRT_LPI2C4}
    #if defined(WIRE_IMPLEMENT_WIRE3)
      , {&Wire3, "Wire3"}
    const uint8_t wirelist_count = sizeof(wireList) / sizeof(wireList[0]);
      //Wire.setSCL(16);
      //Wire.setSDA(17);
      for (uint8_t wirelist_index = 0; wirelist_index < wirelist_count; wirelist_index++) {
        wireList[wirelist_index]._wire->begin();
      int nDevices;
        IMXRT_LPI2C_t * const port = wireList[wirelist_index].port;
        Serial.print(F("Scanning("));
        Serial.print(wireList[wirelist_index].wire_name);
        Serial.println(F(")..."));
        nDevices = 0;
          wireList[wirelist_index]._wire->beginTransmission(address);
          error = wireList[wirelist_index]._wire->endTransmission();
          if (error == 0) {
            if (address < 16) {
              Serial.print("0");
            Serial.print(address, HEX);
            Serial.print("  (");
            nDevices++;
          } else if (error == 4) {
            if (address < 16) {
              Serial.print("0");
            Serial.printf("MCR:%x MSR:%x, MIER:%x MDER:%x MCFGR0:%x MDMR:%x MCCR0:%x\n",
              port->MCR, port->MSR, port->MIER, port->MDER, port->MCFGR0, port->MDMR, port->MCCR0);
      switch (address) {
        case 0x33: Serial.print(F("MAX11614,MAX11615")); break;
        case 0x40: Serial.print(F("PCA9685,Si7021")); break;
        case 0x4A: Serial.print(F("ADS1115")); break;
        case 0x4B: Serial.print(F("ADS1115,TMP102,BNO080")); break;
    Jun 2021
    6
    Thank you again! I tried that code, but is still showing "No I2C devices found"
    Maybe I should use the i2c_t3 library? But the documentation tells that is not compatible with teensy 4.0
    1,689
    I wired a DS3231 to I2C port 1 on a Teensy4.1 and ran the code from @BriComp's msg#4.
    It finds the device:
    I2C Scanner
    Scanning(Wire)...
    Scanning(Wire1)...
    Device found at address 0x68  (DS1307,DS3231,MPU6050,MPU9050,MPU9250,ITG3200,ITG3701,LSM9DS0,L3G4200D)
    done
    Scanning(Wire2)...
    Does your LCD have pullups on SDA and SCL? If not, they are required - I use 3.3K on each of SDA and SCL.
    Pete
    Jun 2021
    6
    Thanks for running the code, I think everything is fine with the LCD because if I connect in port 0 (pin 19, 18) the scanner detectets inmediately, but in port 1 (pin 16, 17) nothing happened.
    1,689
    Post a photo of how you've connected the LCD to pins 16 and 17.
    Does the LCD use 5V or 3V3?
    Pete
    Jun 2021
    6
    Hello Pete!
    Here are some photos
    First the connections in teensy, red wire in pin 16 (SCL1) and blue wire in pin 17 (SDA1)
    Then, connections in level shifter. Red in LV1, Blue in LV2, 3.3v(orange) and GND(Blue) from Teensy. Then in the other side Green to HV1, Yellow to HV2, and 5v and GND from another source, source that also power the LCD screen
    Finally the LCD, green to SCL, yellow to SDA, Orange to VCC and Red to ground.
    "Does your LCD have pullups on SDA and SCL?" I'm not sure about this, but I think yes... otherwise I think it would not work on I2C port 0, and in that port everything is ok.
    2,631
    your code in post #1 won't work on Teensy 4. There are no alternate pins (as in Teensy 3). To use pins 16 and 17 you must use Wire1, e.g. Wire1.begin() and every place you use Wire replace it with Wire1.
    i'm not sure why the scanner in post #4 is not seeing your I2C device ....
    I can confirm that the I2C to parallel adapter boards on the back of these LCDs do include pull-ups on the SDA and SCL lines.
    1,689
    Thanks for the photos.
    In photo #2 there's a pair of yellow (HV) and blue (GND) wires. Where do they go? Are they the same yellow and blue wires that go to Teensy pins 18 and 19?
    Pete
    Jun 2021
    6
    That cables (yellow and Blue) are the reference power for the level shifter (5v and ground)... Do you think could be the library? Maybe someone knows another library that I can use for I2C in teensy 4.0?
    9,207
    Again sort of hard to follow your wiring through the pictures. Sorry it is early in morning for me. Eyes are not seeing straight yet.
    But I would double check the wiring. That is I know I have screwed up before, where you think you can simply move the pins down 2 (19,18) to (17, 16) for Wire1
    But the SCL/SDA are reversed so you need to move 19->16 and 18->17 So I would double check that.
    And I know that Wire1 works with the wire library on T4, unless something has corrupted it recently.
    As for if you are using a library to communicate to the display, other than your own code, you need to make sure that library is setup to handle alternate Wire objects. Some are, many are not.
    1,689
    I don't see how it can be the library. I demonstrated in #6 that the code in #4 (which uses the Wire library) finds an I2C device on Wire1.
    I've added a few other devices on Wire(0) and ran #4 again and it finds all of the devices on the two buses:
    Scanning(Wire)...
    Device found at address 0x51  (EEPROM)
    Device found at address 0x54  (EEPROM)
    Device found at address 0x56  (EEPROM)
    Device found at address 0x57  (EEPROM)
    done
    Scanning(Wire1)...
    done
    Scanning(Wire2)...
    and just for fun I moved the extra devices to Wire2:
    Scanning(Wire)...
    Scanning(Wire1)...
    done
    Scanning(Wire2)...
    done
    I think you have a wiring problem somewhere.
    In the first photo, you have yellow and blue wires on Teensy pins 18 and 19. Where do they go?
    Pete
    I had the parts to duplicate your basic setup with the LCD on Port1. It worked as expected, so I suspect there must be a wiring issue somewhere as others have mentioned.
Name:	LCD1620 I2C on T4.0 Port1 Wiring.jpg
Name:	LCD1620 I2C on T4.0 Port1 Software Output.jpg
    --- Ken
