Results 1 to 3 of 3
Thread: is it possible to upload programs to teensy 3.5 other than using USB?
    Jun 2021
    2
    hello everyone, I just had an accident on my teensy 3.5, the microusb port that should be used for uploading programs is broken and loose, is it possible to upload programs not using micro usb on teensy 3.5? Thank you in advance
    4,071
    In general no, it is not possible. There are unofficial ways to load sketches without micro USB, but you have to load a script that has the download mechanism on to the Teensy first.
    You could solder wires underneath the Teensy connecting the VUSB, D+, D-, and ground pins/pads to a USB female port to use. Or possibly try to remove the current USB port and resolder another on.
    Jun 2021
    2
    ohh thanks Mr., i will try
