Results 1 to 2 of 2
Thread: Confirming TDM stacking header pins
    Aug 2016
    Australia
    192
    I'm tidying up my CS42448/CS5343 8x8 audio board and just want to confirm the pinouts for the stacking header. I've got this list by reverse engineering the Hackaday board pictures.
Name:	teensy stacking tdm header.png
    BTW, the revised board is part of a complete 8x8 audio mixer setup that features:
    • 8x8 fully balanced (other than inputs 7 & 8) Teensy audio compatible board with headers for input and output daughter boards, to provide flexibility and neater wiring to enclosure panels.
    • balanced mic/line preamp boards (up to 40dB extra mic gain, using TS472s gain controlled vI2C DACs)
    • balanced instrument/line preamp boards (very high impedance for guitars etc, up to 20dB gain using DigiPot control and featuring a 20dB pad for very 'hot' signals)
    • balanced line output boards that will drive 600 ohm loads
    • an I2C expander/distributor board to feed I2C and read/write GPIOs (to control the pads/read the input status )
    Here's a picture of the prototype with various prototype generations of boards and lots of messy wiring!
Name:	monirot prototype.jpg
    When the job's complete, I'll post the Eagle files and Gerbers on my github, and make the share the boards on PCBWAY (happy for others to re-share on OSHPark).
    Richard
    Aug 2016
    Australia
    192
    I eventually found the confirmation in another of Paul's Hackaday posts:
    https://hackaday.io/project/176368-d...d-cs42448-chip
Name:	teensy stacking tdm header 2.png
    Others may find the information useful.
