Results 1 to 3 of 3
Thread: Teensy 4.1 accessing the 8 MB built-in Flash
    Feb 2020
    2
    I would like to utilize some of the built-in Flash memory on a T4.1. My application
    uses about 200 kB, so most of the 8 MB is currently unused.
    A pointer to either a forum thread that discusses using this memory, or maybe an
    example of reading and writing to it would be helpful.
    When Teensy Loader uploads a new version of the firmware, does it erase the
    whole 8 MB, or just enough pages (what size are the pages) for the new firmware?
    I'm hoping to be able to have some storage that is persistent across firmware
    updates.
    Thanks for any guidance.
    26,776
    Install the latest beta
    https://forum.pjrc.com/threads/67252...no-1-54-Beta-9
    Use the LittleFS library
    Create an instance of LittleFS_Program for a filesystem which accesses program memory.
    I'm hoping to be able to have some storage that is persistent across firmware updates.
    Unfortunately, you won't get this until we do a bootloader update, which won't come until near the end of 2021 or perhaps sometime in 2022.
    To persist across code uploads, use EEPROM (limited size) or add a flash chip.
    Feb 2020
    2
    Thanks Paul for the pointer.
    -- Philip
