Results 1 to 3 of 3
Thread: Can I use Verilog on a Teensy 4.1
    Jun 2021
    2
    Hi Everyone,
    I'm learning Verilog, and wondered if I can use Verilog with a Teensy 4.1, I can't find any info on whether this board is supported or not.
    Any help appreciated.
    Chris
    24,472
    No. Teensy is a microcontroller, programmed with traditional programming languages. Verilog is used programmable logic and IC design. Teensy 4.1 doesn't have generic programmable logic on the scale of a FPGA or CPLD where Verilog is used. Teensy 4.1 does have tiny AOI logic unit for peripheral triggers, but it's very small and not usable with Verilog.
    You'd need this sort of board to play with Verilog.
    https://1bitsquared.com/products/icebreaker
    Jun 2021
    2
    @PaulStoffregen, Thank you
