Results 1 to 5 of 5
Thread: Where are register names defined in teensydrino for teensy 4.1 ?
    Jun 2021
    2
    The iMXRT1060 reference manual has register descriptions but the compiler does not understand that.
    I'm surprised this is not even in the wiki, but how are you suppose to use a MCU without knowing the register names ?
    The teensyduino core must have a file somewhere with all the definitions.
    Can the devs let us know which file is it ?
    14,456
    The #defines and details needed to build for T_4.x's 1062 MCU are in this 9,000+ line file installed with TeensyInstaller:
    {local arduino}\hardware\teensy\avr\cores\teensy4\imxrt.h
    Jun 2021
    2
    Thanks for the help!
    24,472
    As you read imxrt.h, hopefully you can see we've kept the names identical to register names in the reference manual, so you can just type any register name as it appears in NXP's documentation. Well, at least with the minor caveats where NXP's documentation isn't so consistent, but there really shouldn't be any big surprises.
    14,456
    Quote Originally Posted by 3EB2C70F View Post
    Assume you are referring to this wiki :: github.com/TeensyUser/doc/wiki
    @luni - is there a place for this in the Wiki?
    Looks like the equivalent for T_3.x is :: {local arduino}\hardware\teensy\avr\cores\teensy3\kinetis .h
    >> github.com/PaulStoffregen/cores/blob/master/teensy3/kinetis.h
    For the T_4.x: {local arduino}\hardware\teensy\avr\cores\teensy4\imxrt.h
    >> github.com/PaulStoffregen/cores/blob/master/teensy4/imxrt.h
