Results 1 to 9 of 9
Thread: Recreating Teensy 4.0 on custom pcb
    Jun 2021
    6
    Hi. I'm trying to directly integrate the Teensy 4.0 into my PCB. But I'm running into issues finding the capacitors i need for the MIMXRT1062DVL6A supporting circuitry. And I was wondering why all the caps on the Teensy 4.0 schematic are electrolytic. Because I cant find any electrolytic caps for certain values like 10nF. So is there a way I can use standard non polarized capacitors? Because I can find non electrolytic capacitors for all of the values just not electrolytic ones. Or does anybody know where I can get these capacitors in an SMD format?
    25,064
    Quote Originally Posted by maxall4 View Post
    They're not. All the capacitors are non-polar ceramic, like X5R & X7R. Don't read too much into the shape of the symbol on the schematic.
    Jun 2021
    6
    Thanks for your help.
    Jun 2021
    6
    Also I have one other question on the Teensy 4.0 schematic it says 120 next to some inductors but a unit is not specified is this nH or uH? Same with resistors it says 470 but again a unit is not specified.
    25,064
    That's ohms impedance at 100 MHz, which is the standard way almost ferrite beads are specified.
    Jun 2021
    6
    Thanks. Sorry if that was a stupid question.
    Jun 2021
    6
    I'm also having trouble getting the MIMXRT1062DVL6B. Can i use the MIMXRT1061CVL5B instead or one of the other chips in the 1060 series?
    25,064
    I don't know. It's only been tested with the 2 chips we use on Teensy 4.0 and 4.1.
    Other RT1060 series chips might work, might not. If they don't work, you'll have to just throw those boards out, so don't make too many for the first test.
    Jun 2021
    6
