Results 1 to 5 of 5
Thread: Ethernet port with WIZ850 & Teensy 3.2
    Jun 2021
    3
    I use the Ethernet.h library on a teensy 3.2 communicating with a Wiz850io. I would like to be able to dynamically change (in the setup) the Ethernet port number. I can dynamically change the IP address but not the port. Is it possible ?
    Best regards
    Nov 2015
    Cold hollow VT
    201
    Not sure what you mean here. What do you mean by port number?
    Maybe look at the UDP example I think that references a port number.
    Jun 2021
    3
    Quote Originally Posted by grease_lighting View Post
    and thanks for the quick response.
    The port number is for example 80 or 502 (client server) declared in the instruction:
    EthernetServer server (502)
    And I would like to be able to change this address dynamically (in the setup by going to read the value in EEPROM for example)
    thank you
    Junior Member fdu's Avatar
    May 2021
    lyon
    5
    Dear ,
    In a specific program , i had this ( in EthernetServer.ccp ) :
    void EthernetServer::begin()
    const int Ct_AdrEEPROM_IPPORT = 72 ;
    uint16_t v_port;
    EEPROM.get( Ct_AdrEEPROM_IPPORT, v_port);
    if ( ( v_port< 1 ) || ( v_port> 2500 ) ) {
    v_port= 502 ;
    _port = v_port;
    uint8_t sockindex = Ethernet.socketBegin(SnMR::TCP, _port);
    if (sockindex < MAX_SOCK_NUM) {
    if (Ethernet.socketListen(sockindex)) {
    server_port[sockindex] = _port;
    Ethernet.socketDisconnect(sockindex);
    And in your main program , you must save in the eeprom your new v_port .
    It's work but it's only for one application .
    Jun 2021
    3
    Thank you FDU !
    It's work!
    Regards
