AlwaysIterating
New member
Hello first time poster here.
I am working on a synth using the audio library and ran into an issue while using the audio system design tool. The audio line splits off into 3 paths before meeting back up in a mixer. One goes in dry, one passes through a waveshaper and the last passes through a rectifier. For some odd reason, the dry signal has become rectified even though it should not have passed through the effect at all. I double checked that the pathing in the actual code is correct and as far as I can tell everything checks out. Either I'm missing an obvious mistake or there is some weird interaction happening that goes against the intuitive design tool.
Attached is a zip of my code, a screenshot of the signal chain, and a Pure Data file that I use to modulate parameters while running the synth.
Any help would be much appreciated!
